ScanGuage II
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rellik01, May 12, 2011.
  1. May 12, 2011 at 8:42 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Was wondering if anyone with scanguage II experience can comment on the accuracy of the MPG function.
    Thanks
    Craig
  2. May 12, 2011 at 8:43 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Its right on the money if you dial in your speed and gallons input.
  3. May 12, 2011 at 9:09 AM
    Rellik01
    Craig
    Windermere, Florida
    Thanks for the quick reply.
  4. May 12, 2011 at 1:50 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Yep, it's pretty close if you follow their guidelines like always using the same pump to fill up and not topping off after the pump auto shut off. Mine gets off a little when I start using different pumps at the gas station.
  5. May 12, 2011 at 5:07 PM
    Toby
    Toby Servant of Ninkasi
    Prairieville, LA
    17 Black TRD Off Road 4x4
    None yet.
    IME, it was more accurate before they started putting ethanol in the gas. Since the percentage fluctuates by station, it has been more variable since then. That being said, the variability isn't off enough to really matter to the big picture. I'm just a little OCD.
  6. May 13, 2011 at 6:22 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    just do the fill option. Fill your truck, tell the scanguage, then see how much it thinks you used next fill. Pretty easy and accurate
  7. May 13, 2011 at 6:56 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    I've never tested partial tank fill-ups as I just fill it up whenever I get low, but can attest if you adjust it correctly over the first 4-6 tanks and drive in a consistent manner, it's pretty darn accurate. Mine's never been off by more than .2 mpg from my manual calculations.
  8. May 13, 2011 at 7:01 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya mine is either dead on or .1 off
  9. May 14, 2011 at 3:40 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    I have had mine for three years now and it is amazingly accurate on the fill ups. Almost always within .1-.2 of a gallon when I fill back up. Did they evere figure out the codes for the oil temp or trans temp or pressure on either one of them? :)
  10. May 14, 2011 at 4:49 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    never heard of it. I just use it for the speed, RPM, mpg, and avg mpg. Might swap the speed out but I like seeing the display, make me remember my other baby the 08 civic si :(
