Scared to death while towing a car
Discussion in 'Towing' started by forcefedsupra, Aug 5, 2013.
  1. Aug 5, 2013 at 11:00 AM
    forcefedsupra
    forcefedsupra [OP] Member
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
    I just towed a 2,800 lb. car on a trailor from Houston to Tulsa with my '09 Taco 4x4 dbl cab v6 and was terrified. Any time I touched the brakes they barely slowed me down. Several times I wasn't sure I would stop in time and had a lot of near misses. The tires were howling every time. My truck has the pre-TSB springs so I'm sure that had a lot to do with the front tires howling but what about the brakes? it felt like they were made of mayonaise. I am definitely installing heavy duty pads and upgrading the rear springs. Is there anything else I can do to remedy this? BTW, the trailor does not have brakes.
  2. Aug 5, 2013 at 11:06 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Well you really need a trailer with brakes! You shouldnt even be touching a load over 2000lbs gross without brakes, let alone 2800+trailer weight. Thats your problem right there. That might be doable behind a 3/4 or 1ton truck, certainly not a Tacoma!
    Sounds like the weight distribution of your load may have been a partial issue as well. Make sure you have about 10% tongue weight, almost sounds like you had the car way forward on the trailer causing the front tires of the truck to unload and loose some braking power
  3. Aug 5, 2013 at 11:06 AM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
  4. Aug 5, 2013 at 11:14 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Dead on there Eric....trailer w/brakes & a brake controller unit for the Taco.
  5. Aug 5, 2013 at 11:14 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Relentless nailed it. End thread.
  6. Aug 5, 2013 at 11:15 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Truth. Trailer brakes FTW!
  7. Aug 5, 2013 at 11:18 AM
    forcefedsupra
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
    Are there any brake upgrades that would help? I have not found any big brake kits for the truck.
  8. Aug 5, 2013 at 11:23 AM
    poundin tacos
    poundin tacos Well-Known Member
    Scot
    Dallas, TX/ SFL
    2021 TRD Off-Road, 2018 built Macan Turbo (daily), 2nd gen dodge, 89 944
    I have an 09 access cab prerunner and tow a 24ft boat. Fully loaded with the trailer I'm at almost 4000. The brakes went out on the trailer a couple months ago and I towed it to my buddies house 180 miles away to work on it. I didn't have any trouble whatsoever. Honestly I didn't even notice a difference so your situation sounds a little off to me.
  9. Aug 5, 2013 at 11:25 AM
    forcefedsupra
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
    I'm thinking the brakes are pretty worn so I'm changing them very soon anyway but would like to get the best thing available if I can afford it.
  10. Aug 5, 2013 at 11:29 AM
    YOTA LOVER
    NH
    Relentless mentioned how the OP may not have properly centered the load on the trailer, which can have a large impact on braking. Your boat trailer is built so that the boat is stowed in the best/optimal position over the axles if loaded correctly.
    He could be having brake issues, old fluid, air in the lines, glazed over pads, etc. Hard to tell without knowing.
    That said, and as you've eluded, trailer brakes are very important. Relentless was spot on.
  11. Aug 5, 2013 at 11:31 AM
    YOTA LOVER
    NH
    I ran Hawk pads and LCE drilled and slotted rotors on my 95 when I went up to really heavy tires. Much more dust and less pad life with the Hawks, but they certainly had the ability to bite onto the rotors.
  12. Aug 5, 2013 at 11:48 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Trailer brakes are an excellent ideal. I hauled a 3500 lb snowcat on a trailer up and down mtns for 4 years with my 2007 Tacoma work truck and the trailer didn't have brakes. I used the engine a lot to slow down and assist the brakes. When I retired I had put 40,000 miles on the truck without a brake job. Always had them checked for sure.
  13. Aug 5, 2013 at 11:53 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I towed several cars with a trailer or tow dolly (no brakes) before with no problem although my brakes are in good condition. I have another car that I use as a daily driver and every time I switch to the tacoma, the brakes feel "spongy" but that's the norm for our trucks. I've read people switching to stainless steel lines to solve this problem along with upgrading to better pads and rotors. That's on my to do list.
  14. Aug 5, 2013 at 12:25 PM
    forcefedsupra
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
    I think the non-TSB springs are really hurting too. The truck squats a lot when the trailor is on even without the car on it. But I'm definitely upgrading the brakes and springs before I tow again and will try to get a trailor with brakes also. Thanks guys.
  15. Aug 5, 2013 at 12:28 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Make sure they're on the trailer before towing again. There is a Tundra conversion somewhere, "not my bag baby". Get some spring in yo ass OMD 4wd spring refurbishing.
  16. Aug 5, 2013 at 12:37 PM
    FTD
    FTD Well-Known Member
    My God. It's amazing you weren't killed. I wouldn't put a riding mower on a trailer without brakes.
    Glad you're still with us.
  17. Oct 20, 2013 at 2:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No.
    There are some big brake kits from TRD, and the Tundra brakes can be retrofitted, but they were not designed for towing without trailer assist.
    Keep in mind that in many states it is illegal to tow over 3000lbs without trailer brakes. Get into an accident and you are wide open for a lawsuit.
  18. Oct 20, 2013 at 2:59 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Get a proper trailer with brakes or add brakes to your current trailer. Towing that heavy with no trailer brakes is outright dangerous and it serves you right be scared shitless. You're lucky your piss poor decision making didn't cause an accident.
  19. Oct 20, 2013 at 5:59 PM
    CFI AandP
    CFI AandP Well-Known Member
    Cory
    Florida
    '18 BBP DCSB Limted
    I've had my '13 DCSB 2WD three weeks and did my first tow this weekend. 2,800lb car on a 2,000lb tandem axle trailer w/o brakes. Was about a 30 mile tow with 20 miles of highway in there. Towed like a normal rig, didn't notice any difference than the same set-up being pulled by my previous truck. Well, the Taco did downshift to 4,000RPM to climb the overpasses.
    Cheated death once again.
  20. Oct 20, 2013 at 6:20 PM
    FTD
    I don't mean to sound like an asshole, but you should go turn in your driver's license immediately and never drive again. I mean that. It's a fucking miracle you didn't kill anyone.
