School me on Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fiddynut, Dec 22, 2011.
  1. Dec 22, 2011 at 6:14 PM
    Fiddynut
    Fiddynut [OP] Well-Known Member
    San Diego
    03 TRD Double cab
    Bilstein 5100s on 32" BFGs
    I want to get some stock leafs for my lifted double cab.
    Is there a difference between double cab, standard cab, and Extra cab springs?
    Thanks in advance for the info.
  2. Dec 22, 2011 at 6:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How much lift in front? What are you using to lift the back now?
  3. Dec 22, 2011 at 6:20 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    From the factory there is no difference.
  4. Dec 22, 2011 at 6:37 PM
    Fiddynut
    San Diego
    03 TRD Double cab
    Basically i want to put the truck back to stock. It has one of those Deaver AAL 3pack things.
  5. Dec 22, 2011 at 7:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If I was going back to stock in back, I would consider the 4-leaf pack from Wheelers Offroad. It is advertised as "stock" ride height.
    You could just remove the AAL on your current setup, but its there for a reason. Probably the stock leafs are in bad shape.
    Do you have a plan for the front?
  6. Dec 22, 2011 at 7:22 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    So you're lifted and want to go back to stock ?
    If yes, I would go over to Buy/Sell and post a WTB ad and see if someone has stock suspension components laying around that would work for your year Taco.
    Very likely that you can find what you need there. Often that stuff will have been taken off with low mileage on it.
  7. Dec 22, 2011 at 7:23 PM
    Sunner
    Sunner Well-Known Member
    This x2
  8. Dec 22, 2011 at 7:27 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    i know someone looking to sell there stock leaf pack
  9. Dec 22, 2011 at 7:57 PM
    Fiddynut
    San Diego
    03 TRD Double cab
    Already did!:)
    I have 5100s all around. I was going to keep the front ones. I still have my stock coils. Then run some bilstein yellows in the back maybe with a 1" block.
    Im just not happy with the ride quality.
  10. Dec 22, 2011 at 8:06 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    That's because blocks suck and make the leaf pack fail faster.
  11. Dec 22, 2011 at 8:22 PM
    Fiddynut
    San Diego
    03 TRD Double cab
    Then would shackles be a better choice?
  12. Dec 22, 2011 at 8:28 PM
    TACOMABOSS
    96 SR5 4x4
    over blocks? much better
  13. Dec 22, 2011 at 8:29 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I don't know what to tell you...
    first you say you want to go back to stock then say you want to lift the rear with block?
    and you're already lifted Im confused
    What do you want the final outcome to be?
    To go back to stock, swap leaf packs and 5100s with a local member plus some cash on his end.
  14. Dec 22, 2011 at 8:32 PM
    jflan
    Vancouver, WA
    Are your Bilsteins set at 0.0 with stock coil springs ?
    So you like the front "ride quality" and it's the rear that's too stiff ?
  15. Dec 22, 2011 at 8:40 PM
    Fiddynut
    San Diego
    03 TRD Double cab
    Front I'm running 5100s on the lowest clip with the toytec coils.
    rear is the deaver 3 pack thing.
    I don't like the front ride quality. The springs are to stiff.
  16. Dec 22, 2011 at 8:42 PM
    Sunner
    This just seems to keep going in a circle:goingcrazy:
  17. Dec 22, 2011 at 8:48 PM
    TACOMABOSS
    96 SR5 4x4
    so you want better ride lifted? or go back to stock? im confused :confused:
  18. Dec 22, 2011 at 8:59 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    OP, I suggest you spend some time perusing the the Suspension Lift Info and Tacoma Lift FAQ/Guide Stickies. LOTS of good info... Once you have a better idea of what you have, and what you want, you'll find lots of folks happy to answer questions.
    In the meantime, I urge caution in purchasing used stock leafs. Our trucks' OEM leafs are notorious for going flat prematurely. The that Digiratus recommended is probably a better choice.
  19. Dec 22, 2011 at 9:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
  20. Dec 22, 2011 at 10:21 PM
    Fiddynut
    San Diego
    03 TRD Double cab
    I don't think there was a question of "what do I have" I bought it and installed it. I know what I have. I stated I don't like the ride quality from the front springs. And that I'm looking to go back to or close to stock.
    Scottri thanks for answering my OG question.
    4WD what you're doing is sick and I might look into it as an option. Thanks for the lesson.
