School me on running a drop to a new room
Discussion in 'Technology' started by Gaunt596, Sep 24, 2016.
  1. Sep 24, 2016 at 7:43 PM
    Gaunt596
    Gaunt596 [OP] Well-Known Member
    Matthew
    Central Maryland
    If that's the correct terminology. My gaming PC currently resides in a common room, and I wish to relocate it to my own Room. My room does not have any existing Ethernet jacks so I'd be running a whole new line to the room, most likely through the attic as the house sits on a solid slab. I've built 2 Pc's so I'd like to think I'm not totally tech illiterate but have never tried to set up a connection from scratch. I do have an old phone/cable jack that isn't connected to anything anymore, so I wouldn't have to make new holes in the wall to put in the outlet.
    Is this something I have a chance of getting right or should I be looking to hire somone to get the work done?
  2. Sep 24, 2016 at 7:43 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Lolwut
    Whitetrash likes this.
  3. Sep 24, 2016 at 7:45 PM
    AR15xAR10
  4. Sep 24, 2016 at 7:47 PM
    Gaunt596
    Matthew
    Central Maryland
    Note to self, stop posting on TW from my phone lol
  5. Sep 24, 2016 at 7:53 PM
    AR15xAR10
    I saw that,
    Janice.
  6. Sep 24, 2016 at 7:56 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    very easy. pm me
  7. Sep 24, 2016 at 8:00 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yup easy job. Here too if you have any questions.
  8. Sep 24, 2016 at 8:01 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I did this exact thing a few years ago, got tired of crappy signal from my USB WiFi antenna. Honestly the hardest thing is fishing the cable up/down the wall. I used a cable snake like this:
    https://www.amazon.com/gp/aw/d/B000...able+snake&dpPl=1&dpID=415dCPCVVBL&ref=plSrch
    Since you already have phone cable going there you could even duct tape the Cat5 cable to the old phone line & pull it thru that way. If you can tie your shoe laces you can handle this :fistbump:. Beware of slipping off the attic studs!
    medic2230 likes this.
  9. Sep 24, 2016 at 8:04 PM
    Bennett707
    Oregon
    around here prewired phone wires are stapled unless ran after drywall
    AR15xAR10 likes this.
  10. Sep 24, 2016 at 8:12 PM
    dumontrider
    La Habra, CA
    14 GX460
    Staples just mean 'pull harder' :benchpress:
    ....yes, that's what he said :rimshot:
  11. Sep 24, 2016 at 8:14 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
  12. Sep 24, 2016 at 8:27 PM
    AR15xAR10
  13. Sep 24, 2016 at 10:23 PM
    Gaunt596
    Matthew
    Central Maryland
    what he said^ plus the lines just arent there, they run for about 6" after the jack and then nothing, i think somone already tried the pull harder method lol. also PM's Inbound
  14. Nov 22, 2016 at 12:38 PM
    mmrocek
    mmrocek Name is Bill Burke, and this was an exercise.
    William
    2016 Taco Offroad TuRD
    icons, 4.88’s, winch, sliders, skids and some dinky little 285’s
    I have used this with pretty good success. and I am an IT manager... lol just didn't feel like running wire through the insulated ceiling while it's 120F out here in AZ.
    HutchJ likes this.
  15. Apr 27, 2017 at 4:59 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I would (and have) just bought a cat 5 crimper and a box of cat six cable. I went crazy and made custom cables for EVERYTHING. Modem to router, router to other router, other router to Nas.... Most of my house is hard wired now.
    JohnWJ likes this.
  16. Oct 12, 2017 at 2:59 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Speeds, cat 5, cat 6, are achieved a lot though cable geometry. The number of twists in the pairs. The way the pairs themselves are twisted together. That being said, don't pull around corners, no hard turns.
