+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Apr 16, 2013 at 8:02 AM
    #41
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    haha, bread crumb trail. I like it.
  2. Apr 16, 2013 at 8:54 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Apr 16, 2013 at 9:01 AM
    #43
    BajaRunner
    BajaRunner Rock magnet
    Drew
    Chino Hills, CA
    12 4wd DC Tacoma TRD OR
    Very nice build, love the snow pics.
  4. Apr 16, 2013 at 9:45 AM
    #44
    SconnieHailer
    Marc
    ^ Thanks! Snow wheeln is fun, except when it hides nasties that come out of nowhere...
    You should start a build thread :)
    EDIT: Lol just found it :D
  5. Apr 16, 2013 at 11:35 AM
    #45
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Actually, I just got an up close look at a taco with 285s on it this morning. So now i'm not so sure...
    It looked great, and I didn't see any signs of trimming or CMC.
    :eek:
  6. Apr 16, 2013 at 12:22 PM
    #46
    SconnieHailer
    Marc
  7. Apr 16, 2013 at 4:13 PM
    #47
    bullaculla
    Da big big island!
  8. Apr 16, 2013 at 5:28 PM
    #48
    SconnieHailer
    Marc
    that was my initial thinking too on 65's till they wear out and then see what i feel like :)
  9. Apr 16, 2013 at 9:13 PM
    #49
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I'm really surprised no one has asked this question yet.. or maybe I'm and idiot and there is an obvious answer... If you were using your left hand for the clutch and your right hand to shift.. what were you steering with??
  10. Apr 16, 2013 at 9:25 PM
    #50
    bullaculla
    Da big big island!
    I'm guessing that he wasn't steering while shifting. I think you can take your hands off the wheel for a second or two without crashing. Just shift when its safe while going in a straight line. I'm sure coming to a complete stop and starting again was interesting tho! :D
  11. Apr 16, 2013 at 9:26 PM
    #51
    SconnieHailer
    Marc
    my third leg :D Jk, if you plan ahead you can have all the shifting done and never have a period of steering without hands. This was definitely not as bad as texting and driving...
    I might add most of the time i didnt even clutch. I just used it to get moving then just rev matched and dropped it into gear
  12. Apr 17, 2013 at 4:59 AM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I completely forgot about that ability on that transmission. Right as soon as you let off of the gas you can swap gears without needing the clutch.
  13. Apr 17, 2013 at 8:22 AM
    #53
    BajaRunner
    Drew
    Chino Hills, CA
    Just to clarify, since I went to Icon's all around and did Timbrens on the front and Ubolt flip with Timbrens on the rear, I don't have any rubbing at full stuff when crawling in 4L. I've only experienced lite rubbing when PReRunning, when the suspension is compressing while turning. The rubbing is so lite it sounds like a misquito buzzing in your ear. I've only experienced this once since I installed the new suspension. I don't reget going 285's at all, The additional height gained and traction far out weighs the rubbing issues I had. BFG's aren't that much smaller, they're generally 200 thousandths of an inch shorter than other brands. Thats less than 1/4 inch and less than an 1/8 of an inch per side. The only negative impact of 285's is the loss of mileage and power, but regearing fixes that. Go 285's guys you're already pinstripping the outside of your trucks, whats a little inner fender trimming and CMC chop?
  14. Apr 17, 2013 at 10:54 AM
    #54
    bullaculla
    Da big big island!
    Thanks for the post BajaRunner :)
  15. Apr 17, 2013 at 1:47 PM
    #55
    SconnieHailer
    Marc
    haha, thanks BR. I'll consider em heavily when my 265's are bald. I really want the extra clearance and don't care about the MPG or bit of power loss and should be able to deal with the rubbin.
  16. Apr 17, 2013 at 3:52 PM
    #56
    BajaRunner
    Drew
    Chino Hills, CA
    My pleasure....;)
  17. Apr 17, 2013 at 3:54 PM
    #57
    bullaculla
    Da big big island!
    I think once I get a plate bumper, then I will go with 285s and sell the stock bumper before it gets cut up.
  18. Apr 18, 2013 at 5:19 PM
    #58
    SconnieHailer
    Marc
    Finally getting the sub tuned into the system so I thought i'd throw up a pic of it.
    Hybrid Audio Imagine 10" driver in a Mr Marv sealed box. Powered by a Rockford P-300 mono amp and fed from the Pioneer DEH-80PRS headunit. System finally sounds pretty balanced, as good as it's going to get with the stock speakers...
    Don't mind the messy wires, they're gonna get tucked up under the little shelf in the back bin.
  19. Apr 27, 2013 at 4:19 PM
    #59
    SconnieHailer
    Marc
    Had some fun today :D
    Flexed it out and figured out how much extra clearance the new bumper gives me. Climbing up that little grade today was the first time I really felt A-Trac working and actually helping a ton! I could have just kept crawling up that slope! cool stuff.
    Old Open Pit Uranium Mine. Circa 1970's
    And Snagged a pic of 2 of the bajillion antelope I saw...
  20. Apr 27, 2013 at 4:22 PM
    #60
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Dang. Looks like you are out in the Sahara! That is beautiful.
