Scored a bare front axle housing...what do I need to complete?
Discussion in 'Solid Axle Suspension' started by Guam_98taco, Jun 12, 2019.
  1. Jun 12, 2019 at 1:14 AM
    Guam_98taco
    Guam_98taco [OP] Member
    Philip
    98 Tacoma 4x4
    3 inch block up front, add a leaf in rear
    Just scored a front axle housing. Bare. What do I need to complete other than 3rd member.
  2. Jun 12, 2019 at 6:23 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  3. Jun 13, 2019 at 12:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This could be quite interesting most often better to do the homework before shopping .
    Best of Luck OP
    PAlittlematty, Ritchie and tcBob like this.
  4. Jun 13, 2019 at 5:56 AM
    02hilux
    Planet: EARTH
    A whole bunch of stuff.... hopefully you got it for free and the pumpkin is on the driver side or there's more work to be done
  5. Aug 26, 2019 at 9:40 PM
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    Everything.
  6. Feb 16, 2020 at 8:54 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    You could start by telling us what kind of axle it is. Then we might be able to get you going in the right direction.
    slander likes this.
  7. Feb 16, 2020 at 9:09 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    Not to burst your bubble, but the list is long... Very, very long. The axle housing is the cheap and easy part.
  8. Feb 19, 2020 at 11:03 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It's going to take a while to discern all this extensive information and sort through the ample pictures you posted regarding this axle.
    Next time OP try to be a little more vague on your posts and not so detailed.
    Billison_, Hobbs, whatstcp and 3 others like this.
  9. Feb 19, 2020 at 1:06 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Most people if using Toyota parts bring home the complete vehicle which gives you most of what you need decide on what springs your going to use .
  10. Jun 16, 2020 at 4:24 PM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    Cut out your IFS brackets and put the axle in. There's a few points you may want to consider...
    "A few points":
    tie rod
    drag link
    hydraulic lines
    gears
    gear rebuild kit
    springs or links and coils
    heims or ends
    plating
    brakes
    lines
    gusseting
    shock mounts
    drive shaft
    u-joints
    splines
    tires
    hardware
    tabs
    mounts
    oil pan
    pickup tube
    dipstick reloc
    sector shaft
    locker?
    bearings
    paint
    flapper discs
    welder
    grinder
    sawzall
    curse words
    Or a big fucking wallet to let someone else sort this shit out.
  11. Jun 16, 2020 at 4:25 PM
    esxcli
    Sean
    Reno NV
    Also, the axle housing is one of the least expensive things on the list for SAS.
    It would be like asking, "I found a life vest, what else do I need to water ski?"
    Coma 13, whatstcp, jubei and 3 others like this.
  12. Jun 16, 2020 at 4:26 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    :popcorn:
    slander likes this.
  13. Jun 26, 2020 at 9:02 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the year OEM
    things dont always stay the same year to year
    no need to buy what U cant use
    no less after U definitively know where to start
    U might find one someone has thrashed/broken
    whereby quite a bit can be swapped out
    good luck
  14. Jul 6, 2020 at 2:02 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    if it's a mini truck Toyota front axle housing you also want to make sure it's straight, too. My buddy who is a fabricator built a jig to true used housings before installing them in SFA swaps because most of the ones people get their hands on aren't straight
    esxcli likes this.
