Scraped bottom on a speed bump - now MPG is suffering.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wh013mi1k, Oct 11, 2012.
  1. Oct 11, 2012 at 7:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Well hold on now... lets not get ahead of ourselves :D
  2. Oct 11, 2012 at 7:09 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    So your mudflaps hit...?
  3. Oct 11, 2012 at 7:11 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Dis
  4. Oct 11, 2012 at 7:11 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Not winter gas, but different local fuels. Different areas have different fuel blends. Give it a tank or two and see what happens. We got some bad fuel on the motorcycles recently and lost 5 mpg for a couple of tanks.
    Howard
  5. Oct 11, 2012 at 7:29 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This, those things get hung up on everything. And I am with whipper on the winter mix part, it is about that time of year. I am not entirely certain what they do to fuel in winter either, but I think they add special additives to keep it from freezing in your fuel lines or something. These in turn make mpg go down somehow.
  6. Oct 11, 2012 at 7:37 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The mud flaps are hard plastic, this is very possible.
    IIRC its an anti-freeze additive. More glycol based then ethanol
    Your my god damned hero.
  7. Oct 11, 2012 at 8:51 AM
    shemp
    shemp Well-Known Member
    Ethanol stores 90% as much energy as gasoline by volume, so at a 10% mix, E10 stores 99% as much energy as straight gasoline. By example, that means dropping from, say 20 mpg to 19.8.
    Winter gas is more about ease of starting than about keeping water contamination from freezing into ice. Take your summer gas down to -30 degrees, it has a lower vapor pressure, i.e., lower volatility, and much more difficult to ignite. Manipulating the fuel to increase the vapor pressure is done to make it easier to ignite the fuel while also maintaining an acceptable "at temperature" tendency towards ignition. That is an important balance, because otherwise, when the engine warms up, it would start into preignition.
    So what they effectively do is alter the fuel to use a higher portion of smaller and more volatile hydrocarbons, which store significantly less energy per unit of volume. This has far far more effect on the fuel consumption than the ethanol content.
  8. Oct 11, 2012 at 8:53 AM
    DrewH
    DrewH Well-Known Member
  9. Oct 11, 2012 at 10:18 AM
    wh013mi1k
    wh013mi1k [OP] Well-Known Member
    2012 DCLB TRD SPT V6
    To close the loop on this (because I like to finish everything) - the winner of the "Tacoma Scrape Sweepstakes" is....
    Pugga. He was right [first] - It was the goddamn mudflaps.
    Thank you everyone for the suggestions and insights. This is a great community and I'm happy to have stumbled upon and become a part of it.
  10. Oct 11, 2012 at 10:22 AM
    OZ-T
    Peter North
    British Columbia
    Haha
    You're banned
  11. Oct 11, 2012 at 10:26 AM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    This is what I'm thinking..
    Also OP, what is the difference in your normal driving conditions vs the road trip you went on? These can certainly change things up.
  12. Oct 11, 2012 at 10:34 AM
    wh013mi1k
    I subscribe to the scientific method - so take this with a grain of salt. But the road down to VA I got 18 mpg (all highway) using RI gas; on the way home to RI (all highway again) I got 16 mpg on gas. I use cruise control ~74 mph all the way and maintain as I usually drive at times with no traffic. What the group consensus of "winter" or regional gas would make sense.
    However, before I definitely say that this is the case I would want to repeat the same conditions on my next trip; however, if RI switches to their "winter blend" before Thanksgiving (which is probably likely) I wouldn't be able to test.
    THAT, and I'm way too deep on something so trivial at this point :p
  13. Oct 11, 2012 at 10:42 AM
    Pugga
    Massachusetts
    :woot:
    What did I win?
  14. Oct 11, 2012 at 10:43 AM
    wh013mi1k
    Respect, Pugga... respect.
  15. Oct 11, 2012 at 11:03 AM
    #35
    Pugga
    Massachusetts
    word :cool:
  16. Oct 11, 2012 at 11:14 AM
    #36
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Welcome aboard wh013mi1k! Yep those @&%$# mudflaps are way too low. Alot of guys here either take them off or trim and inch or two for more clearance. As far as your mpg i was wondering...between your test trips is there much elevation difference?
  17. Oct 11, 2012 at 11:29 AM
    #37
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Geez, it's so simple. Going to VA you are headed down, to RI you are headed up. Look at a freakin map.
  18. Oct 11, 2012 at 11:37 AM
    #38
    wh013mi1k
    Negligible. The area of VA I head into is just outside of DC - too far east to hit the mountains. Plus, I would argue that it would be equal both trips as I take the same route down and back.
    BUT, for arguments sake the elevation of RI is 200ft+ and the elevation of Vienna, VA is 358ft+. If the Tacoma is impacted by that small of a delta then I chose the wrong truck to purchase....
  19. Oct 11, 2012 at 12:12 PM
    #39
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    You go girl!
    Yep mud flap then winter fuel.
  20. Oct 19, 2012 at 8:35 AM
    #40
    wh013mi1k
    So quick update - I finally finished up the tank of the "winter blend" and decided to put in a tank of 91 due to some reading on this forum. I have only used 87 for the 2 months I've owned it - but noticed something peculiar....
    Ever since I bought it new 2 months ago I've noticed that my second gear (auto tran) hits hard and has noticeable shudder between 15-20mph - nothing that made me think something was wrong, but it definitely got my attention.
    HOWEVER, with this new tank of 91 octane the shudder going into 2nd gear between 15-20 mph is completely gone. Not even the slightest jiggle.
    Does this even make sense?
