Scratch Remover
Discussion in 'Detailing' started by TRDSport13, Oct 22, 2012.
  1. Oct 22, 2012 at 6:42 AM
    TRDSport13
    TRDSport13 [OP] Active Member
    2015 TRD Sport 4x4
    I have a 2013 Tacoma and am wondering if anyone knows how to get very light scratches out of the plastic used for the interior of our doors? The piece in particular is the dark gray panel directly below the window.
  2. Oct 22, 2012 at 7:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Try a hair dryer??
  3. Oct 22, 2012 at 7:16 AM
    TRDSport13
    2015 TRD Sport 4x4
    Interesting. Have you tried this by chance? Any success?
  4. Oct 22, 2012 at 7:18 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    Sub'd. I have the same issue.
    I assume just use the hair dryer to heat up the plastic? Then what?
  5. Oct 22, 2012 at 7:34 AM
    Janster
    Jandy
    Lancaster, PA
    Never used it on the truck...but have done it on other things/vehicles. Not a cure all and every situation/scratch is different. I got my info online...
    Taken off a forum....
    This is for minor scratches:
    Heat the area, be cautious to not get to close to melt the plastic. Then you just rub them out with your fingers by applying firm pressure while its hot and they disappear.
    If you are unsure try a kick panel first, you will see how it works. As far as the Dash, be very careful, since it has a textured surface.
    Again, take a heat gun or hair dryer and heat up the scratch. Do a little section at a time.
    Do not, I repeat, do not direct the hot air on the plastic long enough to melt or get extemely hot.
    Just to the point where its very very warm to the touch and pliable. Then just use your fingers and use firm pressure and rub out the scratches.
    For deep scratches you may need to fill the area, so this technique will not completely take them out, but will improve the scratch tremendously.
    Or another site:
    http://www.ehow.com/how_7443760_remove-scratches-plastic-inside-car.html
  6. Oct 22, 2012 at 7:35 AM
    TRDSport13
    2015 TRD Sport 4x4
    I'm theorizing that the heat expands the plastic to "lift" the scratches out. When it cools down, no more scratches. Of course, these are very light scratches and I'm being very anal about it, but by God its my truck!
  7. Oct 22, 2012 at 7:42 AM
    TRDSport13
    2015 TRD Sport 4x4
    Ok. Thanks for the help!
