Scrubbing when I turn, solutions??
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtopgun515, Apr 24, 2012.
  1. Apr 24, 2012 at 4:45 AM
    dtopgun515
    dtopgun515 [OP] Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    I'm a rookie at this stuff so bare with me. I'm driving a stock 2wd DC V6 with 265/75/16 tires and rims. I just put a brand new set of BFG At's on the truck this past week. My old tires were Goodyear Wrangler Silent Armour's in the same size. The BFG's are scrubbing way worse than the Silent Armour's ever did when I turn and i'm scared I might eventually screw up the tires. Can I add the Bilstein 5100's to my truck maybe set at 1.5" to reduce the rub or would this not effect it at all?? I have 148,000 on my truck and have never replaced the shocks so I know it probably wouldn't hurt to replace them but I'm trying to figure out options to rid the scrubbing before I ruin an expensive set of tires! Thanks for the input.
  2. Apr 24, 2012 at 7:05 AM
    Hoyle
    Hoyle Well-Known Member
    Davidson, NC
    2014 DCSB 4x4 Black
    Shocks would help a little, not much.. the first hard compression on them will hit that rub spot.. raise them at least 2" and push those tires out with different wheels. did you do the tires yourself? .. tire shop should have know they would rub..
  3. Apr 24, 2012 at 7:06 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Find where they rub and break out the Sawzall.
  4. Apr 24, 2012 at 7:19 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    I've had the rims on the truck since 2007. The old tires were the same size and scrubbed a little bit also just not as much as these tires seem to be. They may of done the same thing its just me being paranoid. Basically I new when I put this size tire on the truck they would scrub I'm just wondering if I lifted the front end would that help with the tires rubbing against the frame.
    They are rubbing the frame when I turn, don't really want to be cutting on the frame. Don't think that would be a very good idea.
  5. Apr 24, 2012 at 7:20 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    chop it up dude! everybody's doing it!
  6. Apr 24, 2012 at 7:23 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    lifting a little may help a little...but better option would be to put different wheels on to push them out just a little bit
  7. Apr 24, 2012 at 7:26 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    A cheaper alternative to buying new wheels would be to buy some Spidertrax wheel spacers, which would push your wheels out and reduce the tire rub.
  8. Apr 24, 2012 at 7:28 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This. ^
    And this. ^
    I'm assume your tires are rubbing either on the frame or the upper control arms? If so those are you are best two options.
  9. Apr 24, 2012 at 8:08 AM
    mjp2
    NJ
  10. Apr 24, 2012 at 8:19 AM
    Yamaha Dave
    ^ A sawzall won't do anything on a frame.
  11. Apr 24, 2012 at 8:22 AM
    mjp2
    NJ
    Good point. Time to go big!
  12. Apr 24, 2012 at 8:45 AM
    Hoyle
    Davidson, NC
    2014 DCSB 4x4 Black
    I forgot to point out in my suggestion, Don't worry about a little rub on the frame.. your not going to hurt those tires and surely not the frame.. just roll with it.. we all do. However raising (lifting) the truck will give some releaf to constant rubbing.. I recall when I put my 33" on, rubbing on every turn and bump, Installed a lift with coilovers and new shocks, this removed most of the rubbing except when I hit a really big hole.. I cranked the front up about 5 more rotations, bingo! .. all rubbing gone.. you just have to work with it..
  13. Apr 24, 2012 at 8:49 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Just curious why you suggest Spidertrax spacers specifically?
    I'm assume your tires are rubbing either on the frame or the upper control arms? If so those are you are best two options.[/QUOTE]
    On the frame I can see where its rubbing when I look behind the wheel.
  14. Apr 24, 2012 at 8:51 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Glad you live so far away that way I can never buy a truck from you!
  15. Apr 24, 2012 at 8:54 AM
    tdubya72
    tdubya72 Well-Known Member
    Tracy
    Longview, TX
    '13 TRD 4x4 DC SuperWhite
    ARB Bumper, WARN Synthetic M8000, ARB intensity LED Floods, OME suspension all around. 18 Fuel Revolvers with Wrangler MTR Kevlar.
    Are you experiencing SCRUBBING or RUBBING. Scrubbing is often referred to as the tire sliding or being forced out of it's normal path of trajectory causing a noise like tire squeal. Thing turning sharp on pavement and hearing your tires squeal a little or "scuff".
    Rubbing is obviously contact between your tire and frame or body suspension components etc....
    Maybe a stupid question but thought it might be worth asking based on your OP.
  16. Apr 24, 2012 at 8:54 AM
    Taco76087
    Robert
    Weatherford,Texas
    On the frame I can see where its rubbing when I look behind the wheel.[/QUOTE]
    I run and many members here run Spidertrax because of their reputation of being quality wheel spacers, you can run other spacers, just most have had very good results from spidertrax. All pro makes spacers as well. I'd stay away from the eBay spacers though.
  17. Apr 24, 2012 at 8:54 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Thats my biggest concern is messing the tires up, not so much the frame. I figure if I put a little lift on it and it helps then that justifies me adding the shocks. Thanks for the input guys.
  18. Apr 24, 2012 at 8:55 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    I run and many members here run Spidertrax because of their reputation of being quality wheel spacers, you can run other spacers, just most have had very good results from spidertrax. All pro makes spacers as well. I'd stay away from the eBay spacers though.[/QUOTE]
    Thanks, i'll check them out.
  19. Apr 24, 2012 at 8:58 AM
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    Yea its def. a "rub" I guess you would say. When I turn the tire is rubbing the frame, I can see where it has rubbed a spot on it behind my tire. I don't think its touching anything other than the frame.
  20. Apr 24, 2012 at 8:59 AM
    mjp2
    NJ
    There's usually very little if any life left in a vehicle if I'm selling it. :p
