SCS SR8 16” vs. STOCK WHEELS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VibratingTaco, Mar 21, 2018.
  1. Mar 21, 2018 at 6:16 PM
    VibratingTaco
    VibratingTaco [OP] Member
    Littleton, CO
    2015 Toyota Tacoma Magnetic Grey DCSB
    3" Toytec BOSS Kit
    Can someone tell me how much the SR8 wheel will stick out as opposed to the stock wheel?
    Offsets and backspacing confuses me. I have dislexia when it comes to this stuff.
    Please don’t be an ass.
    If you can put it into layman’s for me that would be great mmmmmmkay
    excorcist likes this.
  2. Mar 21, 2018 at 6:49 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    If you go with the 16x8 it shows it has 4" backspacing and stock is 4.5" on a 16x7. So those wheels would stick out 1.5" more than stock. The .5 difference in backspacing and the 1" wider wheel.
    VibratingTaco[OP] likes this.
  3. Mar 21, 2018 at 7:38 PM
    VibratingTaco
    Littleton, CO
    3" Toytec BOSS Kit
    Thank you. So where does the offset come in to play? I like how the stock wheels look with 1.25” spacers. Could you perhaps tell
    Me what offset and backspacing I should look for in a wheel when I want no more than 1.25” of the sidewall to stick out from the fender?
  4. Mar 21, 2018 at 7:42 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    It can be confusing.
    Im shitty at math, but Im pretty sure it is like this;
    If backspacing = 1/2width of wheel you have 0 offset
    If backspacing > 1/2 width of wheel you have positive offset
    If backspacing < 1/2 width of wheel you have negative offset
    Less offset = wider front track width (makes wheel stick out further)
    More offset = narrower front track width
  5. Mar 21, 2018 at 8:11 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    hoverlover and VibratingTaco[OP] like this.
  6. Mar 21, 2018 at 8:17 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I know the Tacoma’s have a variety of “stock” wheels. Do they all have the same backspacing? For example, the stock wheels on an SR5 vs factory “beadlocks”.
  7. Mar 21, 2018 at 8:20 PM
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
  8. Mar 21, 2018 at 8:23 PM
    tcjacado
    tcjacado Well-Known Member
  9. Mar 21, 2018 at 8:28 PM
    scotch
    Mark
    Centennial, CO
    Lots of Stuff
    Nope. Depends on the width and design of the wheel.
    Stock specs for tacoma's:
  10. Mar 21, 2018 at 8:31 PM
    scotch
    Mark
    Centennial, CO
    Lots of Stuff
