Seafoam question
Discussion in 'Performance and Tuning' started by Jag868, Jun 3, 2014.
  1. Jun 3, 2014 at 9:53 PM
    Jag868
    Jag868 [OP] Member
    Denver
    09 DBL CAB TRD Off-Road
    flowmaster exhaust, 17" chaos wheels.
    I know this has been posted on here a ton, (in fact, I dont think there is much that hasn't) but I searched and didn't find the direct answer to my question, so I am going to ask anyway.
    My Taco is an 09 with about 82,000 miles on it, and I was looking for a good injector cleaner simply to clean out all of the additives and crap they put in the winter gas. Literally nothing wrong with my truck's idle, etc...
    I was planning on just putting it all in the gas tank, but now I see all kinds of folks doing some in the vac line, some in the oil and some in the gas tank.
    Just wanting to get some feedback and advice. Should I not throw it all in the tank?
  2. Jun 3, 2014 at 10:07 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I LIKE BERRYMAN B-15 CHEMTOOL, ive soaked for injectors and helped out. Seafoam is ok, but get ready for the war youve created
  3. Jun 3, 2014 at 10:11 PM
    tylershane17
    tylershane17 Back to Back World War Champions
    Tyler
    Northwest Alabama
    2007 TRD OFF ROAD DCSB
    Brushguard, Lift.
  4. Jun 3, 2014 at 10:30 PM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
  5. Jun 3, 2014 at 11:15 PM
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    sucked in half a cup through the brake booster line in my buddies b18 back in the day.. gas station attendant called the fire department, fun times....
  6. Jun 4, 2014 at 6:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    http://www.redlineoil.com/product.aspx?pid=80&pcid=12
    Proven to work, by independent labs. Is also a necessary part of the service intervals for Lamborghini's cars. Simply because our fuels are dirtier than European. Extremely concentrated, and returns the system to about 98% of new. Minus the fact that the fuel filter should still be changed as well.
  7. Jun 4, 2014 at 7:15 AM
    Navar
    Corona CA
    Are those independent labs hired by Seafoam?
    I've done titration tests testing the level of detergency in their product. I wasn't hired by Seafoam. With out going into detail their product was only about double of what detergent pump gas offers. Sure it will work? never said it didn't. I would want to spend my money on something that works. I can make recommendations so if interested PM me. If not no worries.
    What I like to do is hook up a scan tool and see if it corrects the air-fuel trim levels and or as well do a before and after smog test to compare those numbers.
    A full on decarb service is what's going to help best. preferable something through the throttlebody followed by a FI cleaner in the tank to finish the job.
  8. Jun 4, 2014 at 8:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My post wasn't about SeaFoam.
  9. Jun 4, 2014 at 9:31 AM
    Jag868
    Jag868 [OP] Member
    Denver
    I guess my questions is more around should I put seafoam directly and exclusively into my tank, or should I make the extra effort of doing the vac line? I have already bought the product. I guess I can always return it, but I was hoping to get it in my truck before a long road trip I am about to take in 2 days.
  10. Jun 4, 2014 at 10:01 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If this is strictly preventative and you don't have any current issues, I would just run it through the gas tank.
  11. Jun 4, 2014 at 10:31 AM
    Jag868
    Jag868 [OP] Member
    Denver
    Thank you. This is exactly what I am looking for.
