"Sealed" Driveline?
Discussion in '5 Lug' started by MowTaco, Sep 5, 2011.
  1. Sep 5, 2011 at 12:39 PM
    MowTaco
    MowTaco [OP] Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Hello fellow 5 luggers
    The other day I was doing some maintainence to get my truck ready for my 700 mile "commute" back and forth to school. I changed the gear oil in the 5 speed and the rear diff. I tried lubing the driveshaft too... no grease zerks to be found. Are the 5 lugs maintainence free in the driveline department?
  2. Sep 5, 2011 at 1:00 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    As far as I know, yes. I think the only thing you can really do with the drive shaft is replace the U-joint.
  3. Sep 6, 2011 at 2:50 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Is this a real question? Hahaha...
  4. Sep 6, 2011 at 2:53 PM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    ^^^ lol...
  5. Sep 6, 2011 at 9:36 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    I had to replace mine a few months ago. Not sure about 1st gens but on the 2nd gens you can get Spicer replacements with or without zerks. I opted for zerks so I can grease them periodically, others may want the sealed ones so they don't have to.
  6. Sep 6, 2011 at 11:33 PM
    MowTaco
    Kansas
    Well one less thing to worry about I suppose. I don't see the original post only a quote... but yes Joel you should probably change the gear oil occaisionally. I went with amsoil 75w-90 gl-4 (I think... I used gl4 and gl5 cant remember which went where) There's a fatty ass bolt at the back of the trans on the bottom and another about 1/2 way up the drivers side... these are the drain and fill plugs. always take the fill out first in case you screw it up.
  7. Sep 7, 2011 at 8:34 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    thanks man :D
  8. Sep 8, 2011 at 4:23 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I believe GL5 can cause premature wear/ corrosion to brass components like synchros. So I wouldn't use a GL5 gear lube in the transmission.
  9. Sep 8, 2011 at 3:56 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    so gl4?
  10. Sep 8, 2011 at 4:00 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    That's what I use.
  11. Sep 8, 2011 at 5:23 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    thanks man i appreciate it :eek:
  12. Sep 8, 2011 at 11:44 PM
    MowTaco
    Kansas
    Ok that's what I did then... gl5 in the diff and gl4 in the trans
  13. Sep 9, 2011 at 12:26 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    If your fill plug doesn't come off, then you can fill it through the shifter.
    I fill through top of shifter. You can be so much more precise. It's fun taking your truck apart too :cool:
    It's a bitch to take off if you never done it and don't know how though.
    Considering how my old truck I put a new transmission in, filled old one up before and old transmission had shift bushing replaced...I've taken it off minimum 3 times. lol.
  14. Sep 9, 2011 at 4:34 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    ^Good to know.
  15. Sep 11, 2011 at 1:29 PM
    MowTaco
    Kansas
    Good to know... but I think I'll stick to the 1-bolt "disassembly" method and take out the fill plug
  16. Sep 11, 2011 at 7:52 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    My truck wasn't lifted.
    You gotta remember I had a 5/6 drop on that truck.
    Anything I didn't have to do underneath the truck was great.
    If I was using my neighbors lift, then sure fill plug would be fine.
  17. Sep 13, 2011 at 3:40 PM
    MowTaco
    Kansas
    True... I got to use a lift so the fill plug wasn't a big deal.
