Searching for a long, narrow, deep case. Help a brother out!
Discussion in 'General Automotive' started by 0210, Dec 15, 2016.
  1. Dec 15, 2016 at 4:33 PM
    0210 [OP] Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    I want to add some storage to the truck's bed. The idea is to have a long, horizontal case sit on top of each wheel well, and right under the bed rails. Need an interior width of 6", and interior height of 7 1/2". Would prefer the case to not be much wider or much taller. Length-wise, the longer the better, up to ~60" long. Having several shorter cases is an option, too.
    The idea is to mount one on each side of the bed, taking up the otherwise useless space above the wheel wells. One side would contain the compressor, hoses, and some recovery gear. Other side would contain the water pump, related hoses, etc.. Lots of applications.
    Not finding anything that matches these dimensions.
    Closest I'm able to find is this ammo can: http://www.sportsmansguide.com/prod...surplus-fat-50-saw-box-ammo-can-used?a=604876 . The same thing, but longer would be awesome.
    Metal and waterproof would be preferred, but I'm open to anything - plastic, wood, etc.
    Anyone know of anything like this?
  2. Dec 15, 2016 at 4:49 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Check out Owens Wheel well boxes
    WHEEL WELL
  3. Dec 15, 2016 at 4:54 PM
    Vancouver, BC
    Thanks for the option. Might be a bit large for me. I looked at various wheel well boxes and none really seemed like they'd work. I have a bed slide in between the wheel wells, so I can't have the box stick out much past the wheel well, otherwise it'll interfere with whatever is on the bed slide. Seems that most wheel well boxes do stick out quite a bit...
  4. Dec 15, 2016 at 4:57 PM
    anonemoose
    Bill
    Big Pine, Calif
    Wasn't too sure why you needed the specific size but that makes sense. I have a Owens on my trailer tongue and love it. A lot thinner material than most so the weight was reasonable, plus got free shipping. Good luck with your search.
  5. Dec 15, 2016 at 4:59 PM
    Vancouver, BC
    The specific dimensions are to fit my Viair compressor as-is. If I took off the bottom plate that it sits on, I could fit it into a 4" wide by 7" tall case, but I'd really prefer to have that little bit of extra room in 6" width.
  6. Dec 15, 2016 at 5:00 PM
    Vancouver, BC
  7. Dec 20, 2016 at 1:01 AM
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    Sounds like your best option would be a custom made set, That's the only way you will get the right dimensions you are looking for.
  8. Dec 20, 2016 at 1:25 AM
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    Looking forward to seeing where this goes.
  9. Dec 20, 2016 at 4:25 AM
    JimNH
    JimNH Well-Known Member
    Jim
    Nashua, NH
    2009 White Dbl Cab, SR5, Tow Pkg, 138K and counting
    Kenwood bluetooth double din head unit trailer brake controller K-Z sportsmen classic 16RBT travel trailer!
  10. Dec 20, 2016 at 9:11 AM
    Vancouver, BC
    Yeah, that's the feeling I'm getting. I actually picked up four hand-held tool-boxes yesterday with the intention of using them for this project (two per side), but they're so flimsy that I don't think I want to bother. Will return them and do this custom.
    Thanks. I've actually already seen all those, and none are close enough in dimensions to work.
