Seat height
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chilic82, Dec 16, 2008.
  1. Dec 16, 2008 at 7:12 PM
    chilic82
    chilic82 [OP] Well-Known Member
    TX
    07 DC PreRunner SR5
    Is there any reason Toyota won't make the seats any higher in the new Tacoma's.Is there anything you can do yourself? I love the truck but the seat height makes it sit like a car.
  2. Dec 16, 2008 at 7:14 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Phone book? :)
    Sorry, couldn't resist...
  3. Dec 16, 2008 at 7:27 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Welcome to TW, What he meant to say was if it was built high enough just for you, it would be too high for the next guy.
    Maybe you could have some spacers made for between the seat itself and the rails. Using the same grade hardware might work. I don't think I'd put the spacer between the floor and the rails. There could be a safety and integrity issue there. Hell, Might be one for the first suggestion too.
    Look into a Mobility type business to see if they make adjusters for the handicapped/little people/and the like.
    How much height is needed?
  4. Dec 16, 2008 at 7:45 PM
    LonghornTaco
    Minnesota
    I bet spacers between the rails and the floor would be better - some high grade steel or something. If you take the seats off the rails, that might be tougher to get back on securely - but I haven't looked at them. But, if you went between the rails and the floor, you might weld the spacer to the floor and simply "relocate" the hole. That sounds pretty strong to me... :)
    Very nice suggestion!
  5. Dec 17, 2008 at 3:03 PM
    09silvertaco
    09silvertaco Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    i wish they were height adjustable like my 4runner. i find myself, even w/it all the way back, i still hit my legs on the wheel getting in and out. and my wheel is all the way up and out.
  6. Dec 17, 2008 at 6:18 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^I have the same issue. I generally whack my legs on the wheel every time unless I get in and out carefully like a grandpa or something.
  7. Dec 17, 2008 at 8:09 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    i had the problem of my keys hitting my knee while driving...it made me realize that the seat height was a little off. easy fix tho with one of those quick disconnects for my keychain.
  8. Dec 19, 2008 at 1:53 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    :confused: I'm only 5'2" and I think the seat height is perfect.
  9. Dec 19, 2008 at 3:50 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Drill a hole in some rubber, cut them into squares, and place them under the "feet" of the seat(where the seats bolt to the floor). That should give you a boost, and still a comfortable ride. I did that in my old truck. Goodluck!
  10. Dec 19, 2008 at 4:11 PM
    frankrizzo1
    frankrizzo1 Well-Known Member
    San Diego
    05 Access Cab TRD Prerunner
    5100's at 1.75, Firestone Destination AT 265/75/16
    I'm 5'9" and also thought the seat was too low in my 2005. I tried to get used to it, but just couldnt. I finally raised the seat about 1 3/4" and now it is absolutely perfect. You can do it yourself easily if you have a little patience. If you must have the seat higher like i had to, Im sure there are a variety of ways to do it if you get creative.......... here is the way i did it. I got all the materials i needed at home depot.
    Since the front seat brackets are angled, you cant just use spacers and longer bolts or else all 4 bolt holes will not line up once raised.
    I used a combination of unistrut square washers and 3/8" washers along with 2 high strength longer bolts up front. In the back I used the stock bolts with 3/8" fender washer through a piece of 1 5/8" deep unisrtut as spacer. Then I secured the rear seat brackets to the unistrut using a 3/8" spring nut, bolt and washer on each side. Everything lines up perfectly, took a few hours to do, and now i am even more in love with my truck :D
  11. Dec 19, 2008 at 4:32 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    make some more front brackets and sell them to the LP!!!!:D:D:D
    The rear i bet they could figure out...
  12. Mar 6, 2010 at 10:35 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Same here... if there was a reasonable way to lower the seat (or take the steering wheel even higher) I'd do it. I've managed to change my habits now to where I don't hit the wheel as much but to do it I slide/turn on the upholstery which will only wear it out faster.
    Time for leather seats!
