Seatbelt Chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zrlee, Sep 23, 2007.
  1. Sep 23, 2007 at 12:59 PM
    Zrlee
    Zrlee [OP] Carolina Alliance
    Greensboro, NC
    08' Tacoma Access Cab PreRunner 4cyl.
    Tinted windows, Rubber Tacoma Bed Mat, Clarion 7" Head unit, Rubber Tacoma Floor Mats, Tacoma Entry Guards, Cruiser Alloy Wheels
    Is there anyway to disconnect or deactivate the Seatbelt chime on a 2008 prerunner when you first start driving.
  2. Sep 24, 2007 at 6:35 AM
    DOT3
    DOT3 Member
  3. Sep 24, 2007 at 12:48 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    i have no chimes in my 07 Dcab at all no door or seatbelt or anything. i dont know why but i dont.
  4. Sep 24, 2007 at 6:55 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    Only the 08's have the seat belt chime.
    To turn the chime off do this:
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    Passenger side instuctions are similar, but slightly different(this requires two people to initialize, according to step 4.)
    1. Turn the ignition switch on (without starting car)
    2. Press the ODO/TRIP switch until the odometer displays "ODO"
    3. Turn the ignition switch off
    4. Turn the ignition switch on while depressing the break pedal
    5. Sit in the front passenger seat. Press ODO/TRIP switch immediately (within 6 seconds after turning the power switch ON) and hold it down for 10 seconds or more.
    6. Continue holding the ODO/TRIP switch and fasten the front passenger's seat belt.
    7. Check that the odometer displays either "b-on" or "b-off" (it will be "b-on")
    8. Press the ODO/TRIP button to change the display to "b-off".
    9. Turn the ignition switch off.
    10. Turn the ignition switch on while depressing the brake pedal.
    11. Check that no buzzer sounds when setting on the front passenger seat.
  5. Nov 26, 2007 at 6:41 PM
    sultan
    sultan New Member
    It worked perfectly. I hated that chime..........................
  6. Nov 26, 2007 at 7:47 PM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Holy crap, all that to turn off a chime? :confused:
    I don't have that chime Zrlee, when does it come on?
    Isn't the light enough? Do they have to do a sound now too? :cool:
  7. Nov 26, 2007 at 9:31 PM
    dbbd1
    dbbd1 Well-Known Member
    It's not right! The 07's do not have a chime. I want one, just so I can shut it off!
  8. Nov 26, 2007 at 9:52 PM
    08toyo
    08toyo Active Member
    08 Prerunner DoubleCab 4x2 SR5 TRD Sport
    Is there anyway of stopping the damn light from blinking?
  9. Nov 26, 2007 at 11:40 PM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Yes. Don't drive without fastening your seatbelt.:rolleyes:
  10. Nov 28, 2007 at 8:37 PM
    08toyo
    i guess for the 2008 all you have to do is follow the steps to turn off the chime for the driver's side because it turned off the passenger side as well. really appreciate the info pb2themax. The chime was really annoying.
  11. Nov 29, 2007 at 8:21 AM
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    I don't see what the point it... As much as I detest the chime as well, its for your protection. Just put on your seatbelt and she shuts up... I am happy with it because of that, i always forget; she reminds me. It's just perfect harmony.
  12. Nov 29, 2007 at 12:44 PM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Mod applied and no problem at all.
    Thanks.
  13. Nov 29, 2007 at 12:51 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You 08 folks should ask for a new thread: Cheat Codes!
  14. Jan 17, 2008 at 4:44 PM
    kasf
    kasf New Member
    08 tacoma sport
    does the seat belt light go out along with the chime?
  15. Jan 17, 2008 at 5:11 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I don't have the chime, so it doesn't bother me. But the flashing light is rather annoying when my laptop bag (or other object) is on the front passenger seat. Anything heavy enough for the truck to think it's a passenger. But it's not annoying enough to do anything about it. If it beeped then maybe. :laugh:
  16. Jan 18, 2008 at 6:29 PM
    soetaco
    soetaco Active Member
    Northeast Ohio
    24’ TRD Off-Road iForce Max
    TRD Black Chrome Exhaust Tip TRD Black Aluminum Running Boards Gator SRX Tonneau Cover Black Raised Tailgate Letters Toyota All Weather Floor Mats
    pb - Thanks for the know how. Worked like a chime errr... charm. Hated the chime even thogh I wear my seatbelt religiously I do tend to unbuckle as I'm pulling down my street or parking lot at work and it was just annoying for those few seconds it was on.
