Second battery with tow package
Discussion in '3rd Gen. Tacomas (2016+)' started by rtadams89, Aug 3, 2020.
  1. Aug 3, 2020 at 9:14 PM
    rtadams89
    rtadams89 [OP] Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    I have a 2017 Limited with factory tow package. I was looking into adding a second deep cycle battery for camping and was reading through all the threads on various charge balances, wiring setups, etc. and then stumbled across a thread that mentioned the stock 30 AMP trailer battery charging circuit (https://www.tacomaworld.com/threads/trailer-battery.342516/). Any reason I shouldn't just put a deep cycle battery in the bed and wire it into the existing Aux 12v charging circuit?
  2. Aug 3, 2020 at 11:49 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    SoCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Do you want a battery in the bed? Doesn’t seem like a great place for it
  3. Aug 3, 2020 at 11:53 PM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    As I only need it when on trips, the bed should be fine. I'm thinking of putting in something like this https://www.amazon.com/Newport-Vess...+Smart+Box+Battery+Case&qid=1596523929&sr=8-2 and then using the terminals to hook it up to a cable with 7-pin trailer plug I can plug into the rear 7 pin jack on the truck. Seems that if that plug really can supply up to 30 amps, it should be enough for keeping the battery topped off while I'm driving or recharging it the next day after using the deep cycle battery overnight.
  4. Aug 3, 2020 at 11:55 PM
    duckytw
    duckytw Well-Known Member
    I would use a dc-dc battery charger then feel free to connect it anywhere you want. It will keep your battery properly charged for long life.
  5. Aug 3, 2020 at 11:57 PM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    Isn't that what the aux battery connection on the 7 pin connector is for? I'm trying not to reinvent the wheel and buy more parts + run wiring if the truck is already set up for this scenario.
  6. Aug 4, 2020 at 12:05 AM
    duckytw
    Nope it'll give you power but not necessarily the best power for keeping the second battery in good condition. For the price of a good deep cycle auto battery, I run https://www.amazon.com/Tecmate-Opti...-LFP-Lithium/dp/B011J76CFE?ref_=fsclp_pl_dp_1 and smaller/cheaper golf cart batteries since I don't use them for starting.
  7. Aug 4, 2020 at 7:54 AM
    b3itz
    b3itz Well-Known Member
    Northern KY
    2016 DBLCab OR SB MT
    If i could do it again, i'd get a secondary battery that is a deepcycle and keep it charged with some dc-dc charger that is configured for the AGM or whatever you have.
    I did the offgrid engineering kit with 2x deep cycles. it's badass and great for my winch and gadgets... but it's too much weight in that one spot i'm afraid - although i have not had any issues YET. Also, the VFTuner bit was a shitstorm to get going, but i did end up getting 14.7 volts from the truck
  8. Aug 4, 2020 at 8:00 AM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC
    I one time tried using the 7-way to charge a deep cycle battery in a trailer and it just trickle charged it. I ended up moving the battery into the tow vehicle with an isolator which it charged much, much faster.
