second gen tensioner replace after only 85k or just belt.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Soylent Green2012, Apr 7, 2022.
  1. Apr 12, 2022 at 6:09 PM
    Soylent Green2012
    Soylent Green2012 [OP] RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    I ll check a few of the ap stores in the area and see what they have. Thanks
    optifree likes this.
  2. Apr 18, 2022 at 7:31 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Any way, i attempted to do the belt in the driveway. Even with the truck on metal ramps maybe 10" of lift no way was i able to even get close to the right position to be able to do the work. Called a shop i knew the owner, his mechanic put the truck on the lift and in 15 minutes has the new belt on.
    Job done...
  3. Apr 18, 2022 at 7:43 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    How much automotive experience do you have? Changing the belt is a 15 minute job with the truck on the ground.
  4. Apr 18, 2022 at 7:54 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Plenty, but on this 4.0 there is a huge front sway bar right in the path. Plus my back is not good, i was hoping to not have to lay on my back to try to do the work, and on the ramps was not high enough to do it without issues, so for me it was money well spent, a chiropractic bill would have been x2 of what he charged me.
  5. Apr 19, 2022 at 7:43 AM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Ah, that explains it. Flat on the back is the way to make it happen. :thumbsup: I wouldn’t be able to if my back was acting up either.
  6. Apr 19, 2022 at 9:58 AM
    Soylent Green2012
    jake
    Apopka, Florida
    I worked in heavy construction for years during the 80's. Killed my back. Been dealing with it since.
  7. Apr 19, 2022 at 10:07 AM
    Soylent Green2012
    jake
    Apopka, Florida
    If you look at my profile page my past rides are shown, the 87 monte carlo, was completely built from a non running shell.
    I did 99% of the work myself including all the paint.
    Steves104x4 likes this.
  8. Apr 19, 2022 at 2:39 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    296k have not replaced belt.
    TexasWhiteIce likes this.
  9. Apr 19, 2022 at 3:47 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Your luck on that will run out.
    Hopefully you will not be in a bad place when it does break or shred. I would at least get a new belt and keep it on hand as a jic
  10. Apr 19, 2022 at 4:38 PM
    Boco10
    ADK
    I do have a new belt. Just in case.
  11. Apr 19, 2022 at 4:52 PM
    Soylent Green2012
    jake
    Apopka, Florida
    Just did serp belt, ac clutch relay, ac amplifier all this week.
    Everything working as it should now. Fingers crossed!!
  12. Apr 27, 2022 at 7:38 PM
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    Just finished this job up. Can confirm the tensioner is a PITA to get to, but you can unbolt the AC compressor and let it drop out of the way without taking the lines off. 202k on the factory tensioner/ belt/ idlers. Bearings all still felt good, belt had a lot of cracking on the ribbed side only.
  13. Apr 28, 2022 at 4:35 AM
    Soylent Green2012
    jake
    Apopka, Florida
    Did you do it flat on the ground in the driveway? Or lifted up ?
  14. Apr 28, 2022 at 7:20 AM
    BadAndy10
    the 541
    '10 DC TRD OR
    Tires on the ground, plenty of room with a lift and 285's. Sway bar was a bit of a pain to work around at times, but had the skid plate off, fan, shroud and radiator hoses all out to replace anyway and change the coolant.
  15. Apr 28, 2022 at 11:18 AM
    #35
    Soylent Green2012
    jake
    Apopka, Florida
    Yes then i could see having the room to work, all that stuff out of the way, the right way to do it... these are some tough old trucks....
  16. Apr 30, 2022 at 4:54 PM
    #36
    Soylent Green2012
    jake
    Apopka, Florida
    As noted in post 32, i just replaced my clutch relay, ac amplifier when the serp belt was done. I also replaced the maf sensor and cleaned the intake. In town mpg was borderline 12, after the replacement was added the in town mpg jumped to 17.3 thats a pretty good increase of about 30%.
    My on the highway mpg was around 19. I have not been on a long trip to check it but i know it will be much better. Im hoping for 23 +
  17. May 1, 2022 at 11:58 AM
    #37
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Gates has a good reputation for belts and pulley/bearings. Bando, I believe, is the belt supplier for our Tacos.
    If your pulleys are in good condition, you can replace the bearings and re-use your pulleys. I’ve gone this route on all the vehicles in my household. I have a DIY thread:
    https://www.tacomaworld.com/threads...arings-in-the-idler-tensioner-pulleys.480961/
  18. May 1, 2022 at 12:26 PM
    #38
    Soylent Green2012
    jake
    Apopka, Florida
    Mine is already finished but thanks though.
  19. May 1, 2022 at 1:28 PM
    #39
    Chuy
    Lakeside, CA
    Silver Taco
    For next time, and/or if helping a buddy.
  20. May 1, 2022 at 2:31 PM
    #40
    Soylent Green2012
    jake
    Apopka, Florida
    Yeah, im like that too, just putting things out there that others can use if in a similar situation. Im just glad i didnt have to replace my ac compressor. Who ever engineered this engine to have the oil filter on the top side as apposed to underneath was a freakin genius.
    Makes my life a Breese.
