Secondarily airfilter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco truck1, Oct 23, 2017.
  1. Oct 23, 2017 at 3:17 PM
    Taco truck1
    Taco truck1 [OP] Member
    2009 doublecab trd 4x4 v6
    None
    What is the airfilter that is in the intake housing on my V6? How do you clean it? Can you remove it? Will it help your fuel mileage?
  2. Oct 23, 2017 at 4:38 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A charcoal filter. Some people remove it for "more performance". It's 'permanently' mounted.
  3. Oct 23, 2017 at 4:42 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Oct 23, 2017 at 5:24 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    2009, 4.0
    He shouldnt have that pump.
    I think he means the filter mounted inside the intake housing, the foam 1.
    Edit... i think its foam? I never messed with mine
    Some have removed it and claimed better mpg, some say better throttle response.
    Gadget at urd has ripped out all air filters from a tacoma and seen zero gains on a dyno compared to leaving the intake bone stock.
    So, the butt dyno seems to be the culprit again.
  5. Oct 23, 2017 at 5:29 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Ah okay sorry
    inwood customs likes this.
  6. Oct 23, 2017 at 5:31 PM
    inwood customs
    Dave
    U make me wonder about our camry... i think it has that pump.
    2017
    2.5L
  7. Oct 23, 2017 at 6:33 PM
    blur
    blur Well-Known Member
    It's a charcoal screen. Drill the rivets out and throw away. It's not needed and you'll gain a bit of throttle response.
  8. Oct 24, 2017 at 7:26 AM
    Taco truck1
    None
    Thanks for all the reply’s. Does anyone know if there is a way to clean the secondary filter or do ya just leave it for eternity?
  9. Oct 24, 2017 at 9:02 AM
    Taco'09
    Taco'09 Well-Known Member
    Its charcoal and intended to capture the small HC poofs backwards that occur sometimes on shut down. Removing it may make a difference on the 2.7 but not the 4.0 as it has been dyno'd with and without. So don't waste your time.
  10. Oct 24, 2017 at 9:54 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    also if you want to pass smog here in ca technically you have to have it in.
  11. Oct 24, 2017 at 10:38 AM
    Taco truck1
    None
    Thanks taco 09 I will just forget it’s there
  12. Oct 24, 2017 at 10:40 AM
    Pigpen
    Dan
    Northwest Montana
    Best thing to do
