Secondary air filter?
Discussion in 'Performance and Tuning' started by BajaTrd, Apr 3, 2008.
  1. Apr 3, 2008 at 3:49 PM
    BajaTrd
    BajaTrd [OP] Member
    05 Prerunner, debadged, afe air filter, magnaflow exhaust, ORW bed supports,Camburg spare tire mount
    I know the 2006 tacomas have them, but does the 2005 have it to?
  2. Apr 3, 2008 at 4:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    it should...all the engine components have been the same since 05 i do believe...i do see that u've got an afe...is that a stock replacement type?
  3. Apr 3, 2008 at 4:00 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    2005 is the first year for the secondary air filter
  4. Apr 3, 2008 at 4:04 PM
    BajaTrd
    BajaTrd [OP] Member
    So I've read about people removing this filter. What are the benefits if any of doing this?
  5. Apr 3, 2008 at 4:05 PM
    BajaTrd
    BajaTrd [OP] Member
    Yeah I replaced the factory toyota engine air filter with the AFE
  6. Apr 3, 2008 at 4:06 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It's debatable. A lot of people claim that it helps out, but I'm not sure if it worth modifying your intake for.
  7. Apr 3, 2008 at 4:06 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Big thread on this, diregard my naive comments thoough, if u read em!
  8. Apr 3, 2008 at 4:06 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    2005 and up, remove it it's worthless. Or invest in an intake that deletes entire stock piping and box set up.
  9. Apr 3, 2008 at 4:17 PM
    BajaTrd
    BajaTrd [OP] Member
    So by removing it will I be breathing in the nasty crap the comes thru the cabin? Also I'm assuming if removed there's a big hole hole there right?
  10. Apr 3, 2008 at 4:20 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    It's an engine intake, has nothing to do with you breathing stuff inside, unless you have your exhaust routed to your cab.
    There is no hole. It's a SECONDARY filter meaning, it comes after the initial air filter.
    I think you're misunderstanding what it is you're asking. This is not the cabin air filter but a filter on the engine intake.
  11. Apr 3, 2008 at 4:22 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    now I'm lost. The secondary air filter is for the engine intake. The cabin air filter is on 2006+ and only filters the air for you air conditioning.
  12. Apr 3, 2008 at 4:29 PM
    The_Hodge
    SC
    if u take the intake part off like ur going to replace that afe, the thick filter to the right, that is still attached to the intake housing, is the secondary. its supposed to keep minor gas fumes from exiting out the intake when u cut the truck off. u'll notice a difference if u take it out...power and mpg's
  13. Apr 3, 2008 at 4:32 PM
    roxspin72
    NC
    Oh Yeah!!!
    You are mistaking this filter for the cabin filter behind your glove box. look at the pics I posted. this is above the motor and is closest to the TB when you open filter box.
  14. Apr 3, 2008 at 4:48 PM
    no_werries
    so what 2005 dosnt have a cabin air filter, or just a variation?
  15. Apr 3, 2008 at 4:57 PM
    The_Hodge
    SC
    the 05 should have a cabin filter as well...but its behind the glovebox. if u take the glovebox out, u should see a flap w/ 2 clips on it. pop the 2 clips down and there should be a thin, white filter in there that looks like a mini housebold a/c filter. that is the cabin filter. they do need changing. i told tacorock about his and he popped it out and he had pinestraw and leaves and all kinds of crap stuck in there. the dealer wants $35 for a new one....u can get em on ebay shipped for like $12
  16. Apr 3, 2008 at 4:58 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I read that someone with a 2005 had the space for it, but no filter.
  17. Apr 3, 2008 at 5:09 PM
    no_werries
    ye i figured that the thread on cabin air filters applyed to me, I know they need replacing, i could care less about the air i breath, and that will be something that i more then likely do one day when I feel like i have to much money sittin round, did i mention im poor!
  18. Apr 3, 2008 at 5:20 PM
    The_Hodge
    SC
    u can remove it and blow it out and be ok as well...just make sure u read the side on which way t goes back in
  19. Apr 4, 2008 at 4:04 AM
    no_werries
    cool thanks for the tips, luckily however naive i am about some things, im am a fair handyman for my age.
