Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Apr 1, 2017 at 5:20 PM
    #661
    92PathSE
    92PathSE Well Known "member"
    GA
    Any idea if swapping out the ECU to an earlier non-pump/valve 4.0 would work?
    DesertRatliff likes this.
  2. Apr 1, 2017 at 5:43 PM
    #662
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    Save all of your paperwork and maybe they will start reimbursing everyone with this problem, like they did with the Tundra.
  3. Apr 1, 2017 at 10:00 PM
    #663
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    this same thing happened to me 2012 with 49990k miles. I have filed a complaint with the NHTSA. This is crap that toyota wont cover this known fault.
    BTW- has anyone rebuilt this valve assembly? Is it possible? i have the old one in a box but might want to rebuild now for when i hit 100k
  4. Apr 3, 2017 at 1:21 PM
    #664
    T U N A
    T U N A Member
    2012 Tacoma
    Reposting this from another thread
    I am new to the forum and just received my first P2442 on a 2012 V6 TRD with 50k. I griped to everyone at the dealership and made the call to corporate (800-331-4331) who are reviewing my case and getting back to me within a couple of days. Depending on how that ends up, I am planning on replacing the Valve that is stuck open myself. Do you gents recommend that I also replace the foam filter and plastic fin in the pump while I am in there? Will that help against any future expense or pump failure?
    The dealership half acknowledged the problem, claimed the stuck open valves was electrical and not covered by the emission warranty (which is bullshit) and sent me on my way.
  5. Apr 4, 2017 at 7:42 AM
    #665
    Large
    Large Red
    I just replaced my valves .. left my pump the way it is.. 94k miles and the pump is fine
  6. Apr 4, 2017 at 11:42 AM
    #666
    T U N A
    T U N A Member
    2012 Tacoma
    Thanks Large, Good to know, probably the route I will go.
    Heard from Corporate Toyota and they stated that if I got a diagnostic check done at the dealership, they would wave that fee if I got it repaired at the dealership, and cover 50% of the cost. I am still thinking of saving the few hundred dollars and doing it myself
  7. Apr 4, 2017 at 2:21 PM
    #667
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Do it yourself, even going with the 50% off they are still making money on you.
    Woodchuck234 likes this.
  8. Apr 5, 2017 at 10:51 AM
    #668
    Moose66
    Moose66 Active Member
    Jake
    2012 MGM Tacoma TRD Sport
    Replaced my valve this morning, took about an hour and twenty minutes. Back exhaust tube bolt is a pain to get to but nothing too terrible. Truck is running good so far!
    Soul Surfer likes this.
  9. Apr 5, 2017 at 12:12 PM
    #669
    Moose66
    Jake
    Also wanna mention that when I removed the hose going to the pump I literally poured water out of it... what size filter are people putting on the pump to help prevent this?
  10. Apr 6, 2017 at 3:32 PM
    #670
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It could be possible but the materials have to withstand the high heat under hood temps.
  11. Apr 7, 2017 at 4:54 AM
    #671
    blur
    blur Well-Known Member
    That's not a bad idea but isn't some moisture coming from the exhaust too?
  12. Apr 7, 2017 at 5:32 AM
    #672
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Probably not. Water is a byproduct (output?) of the catalytic converters, so the moisture is downstream in the exhaust, not upstream where the pump is.
  13. Apr 7, 2017 at 6:24 AM
    #673
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Huh? Gasoline is a hydrocarbon with on average a bit over 2 hydrogen atoms per carbon atom. Combustion products are therefore about one water molecule per carbon dioxide/monoxide molecule. There is *gobs* of water vapor coming out of the exhaust valves of the cylinders.
    The catalytic converter does three things. It oxidizes CO to CO2, it converts NOx to N2 and O2, and lastly combusts any partially burned hydrocarbons to CO2 and H2O. That last step is of course vanishingly small compared to the combustion happening in the engine. The cat adds barely any water vapor to the exhaust, almost all of the water vapor was made in the cylinders.
    So there is in fact gobs of water vapor where the valves are.
    EdinCincinnati and Soul Surfer like this.
  14. Apr 7, 2017 at 7:04 AM
    #674
    Scott B.
    Scott
    Georgia
    I stand corrected. Obviously, my engineering background does not include much chemistry...
    DVexile[QUOTED] likes this.
  15. Apr 7, 2017 at 7:17 AM
    #675
    DVexile
    Ken
    No worries! And to be clear, even if that's the correct chemistry I have no idea if the water vapor that's in the exhaust is really what causes the issue with the valves. I assume it is because the "fix" Toyota has in later models is to purge them with fresh air on shutdown which would only seem to be useful if the source of the issue was the exhaust gasses. But there is more than just water in the exhaust gases so the purge could be dealing with something other than water entirely.
  16. Apr 7, 2017 at 7:42 AM
    #676
    Scott B.
    Scott
    Georgia
    Your chemistry is pretty close - I looked it up! LOL
    Now I am wondering where I heard the idea about the cats and water. Thinking about it, that idea makes no sense - I should have looked into that idea long ago.
  17. Apr 8, 2017 at 11:19 AM
    #677
    TacoJohn12
    TacoJohn12 Well-Known Member
    Jonathan
    Escondido, CA
    '16 Tacoma - JD Fabrication Long Travel Build
    4" LT, LCA Pivot Kit, SUA, Howe Steering Pump, Switch Pros, Baja Designs lights everywhere, Fabricated Inner Fenders, Custom bumpers, bedcage Fox shocks: 2.5x8 COs, 2.5x8 bypasses, 3.0x16 bypasses, 2.0x2 bumps on all corners... & more
    I just ran into this issue on my 2012 Tacoma (76k miles) and I may have a (temporary) fix. My truck kept throwing the P2441 code and going into limp mode. I just took the secondary air injection valve off and cleaned off a lot of the carbon build up with a dry rag. It's only been a week but so far but I haven't had any codes.
  18. Apr 8, 2017 at 2:34 PM
    #678
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
  19. Apr 9, 2017 at 5:35 PM
    #679
    Large
    Large Red
  20. Apr 10, 2017 at 8:57 AM
    #680
    conquistador
    conquistador Well-Known Member
    Tulsa, OK
    88 4Runner
    Add me to the list. 40,000 miles and my valve is stuck open. After owning many Toyota trucks over the years I'm done. Never again. Filing a complaint but I don't want to fork over any money to the dealer for a diagnosis. I'd rather throw these parts through their dealership windows.
