Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Apr 29, 2017 at 5:58 AM
    #701
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
  2. May 8, 2017 at 4:28 PM
    #702
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    So i am trying something today, I ordered the dorman air valves for a tundra. The valves look the same as the tacoma ones but the connectors are pointing a different direction. Going to take the valves off the dorman part and mount them to the tacoma body. Will let you know how it goes
    Update: Swapped the valves over. Got the pump to run 4 times and no codes. So far so good. There are some slight differences in the valves. The connector is on the opposite side of 1 valve, but that's fixable.
    The wiring for the stock valves goes to a small bracket in front of the valve. It can be removed and the wiring routed around the inside of the valves to reach the connector.
    The other difference is the length of the air spout which is fine, just don't push the hose all the way on or you will block the air flow.
    Original valves.
    New valves.
    The 1 way check valve
    New valves on original housing
    Wiring originally went around the left side of the photo. Removed the bracket and rerouted to the other side.
    Longer inlet spouts.
    Tommorow I will program my ecm with the update to make the pump run after shutdown and will keep people updated
    Sorry that my photos are so big, i dunno how or why that happened.
    mabepossibly, Large and Soul Surfer like this.
  3. May 9, 2017 at 10:27 AM
    #703
    Large
    Large Red
    How do you plan on doing this
  4. May 9, 2017 at 10:59 AM
    #704
    Twalt87
    Travis
    Vancouver island Bc
    Is there not a tsb for a new flash that gets the 12 tacos to do the same as the 13s? I will have to read the updates and see what they do.
    We have a drew tech flasher at my work. Works great. Just gotta pay the subscription fee for what every make your programming.
    Update: Looked at the available ecu updates through toyota, there is none for the air system, theres one for spark knock, one for surging after cold soak, and one for abs module.
    Does anyone have a 2012 tacoma where the pump runs after shut down? I'm going to throw the latest update on anyways to see what happens.
  5. May 9, 2017 at 7:23 PM
    #705
    crazeepetrvs
    crazeepetrvs New Member
    Happened to me yesterday on my way to work. 2012 tacoma 4.0 4WD with 24k miles. p2442 and the others. toyota said its not covered and they want $2000 to replace valves and pump. going to see if another dealership will cover it. filled out the poll and nhtsa complaint
  6. May 9, 2017 at 7:23 PM
    #706
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    How much did the Tundra valves run you? Pretty good idea, the one way valve on those looks like a better design as well.
    As far as I know for the pump running after shutdown the 2012's don't do it, Toyota must had realized there problem and fixed it on the 13' and newer trucks.
  7. May 9, 2017 at 7:30 PM
    #707
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Just did a quick search for price...179 bucks
    http://www.partsgeek.com/82sx8k9-to...pM7RFbvfpmZOQFYDPkM957Gci1lqpmmHSiGgKc5PD_BwE
  8. May 10, 2017 at 7:08 AM
    #708
    Twalt87
    Travis
    Vancouver island Bc
    I yea sorry forgot to post the part number. That is the part I used. And still working so far.
  9. May 10, 2017 at 1:16 PM
    #709
    Deezee
    Deezee New Member
    Just happened to me this morning p2440 and p2442. Does anybody know where to order the valve assembly in Canada. Thanks
  10. May 10, 2017 at 2:46 PM
    #710
    Large
    Large Red
    Sorry .. don't think I've seen anyone in here from Canada about a failure.
  11. May 10, 2017 at 2:47 PM
    #711
    Twalt87
    Travis
    Vancouver island Bc
    my parts store was able to order the dorman part. #911-643 in bc.
    It happens in canada lol, theres my truck plus 2 that work for the town all with the same problem, all 2012s with less then 60k kms
    Also welcome to the forums fellow canada person
  12. May 10, 2017 at 2:48 PM
    #712
    Large
    Large Red
    :thumbsup:
  13. May 10, 2017 at 5:52 PM
    #713
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Airdog[QUOTED] likes this.
  14. May 11, 2017 at 9:12 PM
    #714
    Twalt87
    Travis
    Vancouver island Bc
    Yea the reed valve seemed beefier. The only issues i had swapping my valves was the torx bolts were seized solid so i had to break em off and weld em out lol. Also, pump has now run over 20 times and no codes. So i can pretty much say with confidence that they are working. Now i even read somewhere that the valves for some chevys are the same, so may be able to source them cheaper yet
  15. May 14, 2017 at 10:57 AM
    #715
    Large
    Large Red
    Has anyone's pump AND valves failed? It's usually either or, not both.
  16. May 15, 2017 at 2:00 PM
    #716
    doorsidedown
    doorsidedown Well-Known Member
    Well, count me among the disappointed. 2015 TRD Pro with 23k miles and I threw P2443 today. Took it into my dealer and they're replacing everything under warranty. I can't speak highly enough of how they dealt with this for me. I'll update as needed.
    LocoLocal likes this.
  17. May 15, 2017 at 2:04 PM
    #717
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Interesting - a 2015. Was it a broken pump or corroded valves? I know one recent truck ingested the filter in the pump which broke the vanes in the pump and then tore up the valves. So far corroded valves have almost exclusively been 2012s.
    Would love to hear any details you have or get from the dealer. Glad they are taking care of it under warranty.
  18. May 15, 2017 at 2:15 PM
    #718
    doorsidedown
    I'll know more after the work is complete- but what I know now is the valves were stuck closed. If you have specific questions you want me to ask them when I pick it up, let me know and I'll write them down and take them in.
    DVexile[QUOTED] likes this.
  19. May 15, 2017 at 4:03 PM
    #719
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Surprised to see a 2015 with the issue, sorry for your luck. On the bright side maybe if 2013-up trucks start failing as well then maybe just maybe Toyota might finally take care of Tacoma owners for this issue.
    doorsidedown[QUOTED] likes this.
  20. May 15, 2017 at 4:36 PM
    #720
    DVexile
    Ken
    Thanks! If you can ask them two questions:
    1. Was this just the valves or was there anything wrong with the pump?
    2. Did the valves look corroded or did they fail in some other way?
    The 2012s are failing typically due to corrosion from moisture. The 2013 and later purge the valves by running fresh air through them just after the engine shuts down to in theory prevent this. So we are all curious if your 2015 failed because of moisture induced corrosion or if it was something else that caused the problem. Certainly any part in an engine can fail unexpectedly so maybe you were just unlucky here and had a defective part. Or maybe the purge "fix" they applied to the 2013 and later doesn't do as good a job at preventing corrosion as hoped.
