Secondary Air Injection System "fix"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Hunter, Jan 11, 2016.
  1. Feb 11, 2016 at 8:31 PM
    #41
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Just came across this thread, I just went through this with mine. I don't think the pump is what we have to worry about but the valves themselves. My valves failed and were horrible and had lots of water intrusion within the system, just like the tundra's. The tundra's had a bad air intake by design for the pump, with ours I think its condensation buildup within the system and it has no where to go. That being said I will probably eliminate the pump filter as well just to be on the safe side. Pictures of my valves are in this thread https://www.tacomaworld.com/threads/secondary-air-injection-switching-valve.381997/page-7
    Bigtom68 and tornado like this.
  2. Aug 6, 2018 at 5:39 AM
    #42
    tacomahillbilly
    tacomahillbilly Active Member
    Georgia
    Like TX Pro, I cannot find one of these damn things on my truck....was there any answer why as to why certain trucks may not have them? 4.0 4x4 SR5 here
  3. Aug 6, 2018 at 5:48 AM
    #43
    Clearwater Bill
    Billy
    Largo Florida
    What year? Your profile is bare.
  4. Aug 6, 2018 at 5:51 AM
    #44
    tacomahillbilly
    Georgia
    oooppss Sorry , 11 model, from what I can tell some of the 05 to 15 models had them but some did not, thanks Clearwater Bill
  5. Aug 6, 2018 at 5:53 AM
    #45
    Clearwater Bill
    Billy
    Largo Florida
    IIRC this started in '12 on 4.0's
    big_jarv and sioux like this.
  6. Aug 6, 2018 at 5:55 AM
    #46
    tacomahillbilly
    Georgia
    Thank you Bill! so prior '12 a V6 4.0 (4x4 or not) does NOT have them?
  7. Aug 6, 2018 at 5:57 AM
    #47
    Clearwater Bill
    Billy
    Largo Florida
    No authority here, but that seems like what I recall reading somewhere.
    I have the 2.7, and have done the mod. Using a Uni filter, not the K&N product.
  8. Aug 6, 2018 at 6:06 AM
    #48
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    On the 4.0 it was introduced in 2012.
  9. Aug 6, 2018 at 6:09 AM
    #49
    Pigpen
    Dan
    Northwest Montana
    Yep
    Only 12 - 15 models have it on the 4.0. All 2.7 2nd gens have it.
  10. Aug 6, 2018 at 6:15 AM
    #50
    tacomahillbilly
    Georgia
    Thank you both for the info, I was not aware it was only 12 to 15 models.
    TXpro4X4 likes this.
  11. Aug 6, 2018 at 6:23 AM
    #51
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    From what I know, you are correct. The '12's were the first with them, which is why they're most prone to issues and have the extended warranty. Had mine fail at about 38k - Valves and pump replaced at no cost. My failure was at the valves (which the majority seem to be), so the uni-filter mod was worthless.
  12. Aug 6, 2018 at 6:35 AM
    #52
    Clearwater Bill
    Billy
    Largo Florida
    So your failure was not related to foam filter deteriorating and being ingested into the system, but the actual control valves?
  13. Aug 6, 2018 at 7:33 AM
    #53
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    Correct. And I believe that's been the majority of people's issues, however they always replace both. I have heard some have had the foam filter issue, but it seems to be by far the minority.
  14. Aug 6, 2018 at 8:51 AM
    #54
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    My 2014 2.7 is no highway queen. I have had my pump under water several times, and once was stuck for a good 3 minutes with water over headlights. When I got home took pump all apart, aside from being wet, looked fine in there. I don't see what all the fuss is about?
  15. Aug 6, 2018 at 9:48 AM
    #55
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    We should feel lucky.
    Less to wrong and when doing a water crossing nothing to suck in water perhaps.
    I'd say it's a win win there!
    :fistbump:
    Why they added it is beyond me :notsure:other than smog. Which bs.....
  16. Aug 6, 2018 at 12:24 PM
    #56
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    if you stay out of mud and slop u never need to worry about it
  17. Jan 8, 2021 at 7:02 AM
    #57
    pinktaco808
    pinktaco808 Hot Steppa
    How we fix the valve from sticking or clean it out? Also how do we unplug and plug the it back together I'm having a hard time disconnecting them
