Seeking Lift Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fknayryt, Apr 19, 2014.
  1. Apr 19, 2014 at 7:28 AM
    fknayryt
    fknayryt [OP] Member
    Bob
    Shorewood, IL
    My truck is a 2006 Dbl Cab Off Road 4WD with 100K on the clock. And I want to lift it up nice and level without compromising ride quality and handling too badly. It's my daily driver, so I don't want to get too carried away with the lift height, but I still want to lift it.
    After reading a lot of posts on the topic, I'm thinking Bilstein 5100's all around, with the fronts set to 1.75.
    What's a good direction to go with the rear leafs to level it out?
    And what's the best coil spring option in the front?
    Bob
  2. Apr 19, 2014 at 8:21 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Add a leaf for the rear springs will keep money in your pockets.
    Front springs most people run ome springs.
    You seem like you're going in the right direction
  3. Apr 20, 2014 at 5:13 AM
    fknayryt
    Bob
    Shorewood, IL
    Thanks. Any recommendations on a preferred vendor for the Add-a-Leafs and springs?
  4. Apr 20, 2014 at 5:30 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    If you want to do an add a leaf go with the icon 3 leaf progressive leaf pack or wheelers version. This will give you a better ride than just a single add a leaf.
    With 100k on your truck you might just want to consider replacing the whole leaf pack
  5. Apr 20, 2014 at 5:52 AM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
  6. Sep 14, 2014 at 7:21 AM
    fknayryt
    Bob
    Shorewood, IL
    Ended up getting everything from Wheelers. Great vendor. Their customer service is excellent.
    Specific equipment I bought was:
    FRONT:
    Bilstein 5100 adjustable ride height shocks (set to max lift)
    Old Man Emu 885 coil springs
    REAR:
    Bilstein 5100 shocks
    WHE MP3HDX 3-leaf progressive Add-A-Leaf set
    Leveled the truck out nicely. Very stiff ride, but I don't care because it looks cool as shit.
    The only thing I would do differently is to pay the extra $120 to have them mount the springs onto the shocks using new rubber bushings. Worth every penny.
  7. Sep 14, 2014 at 7:26 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    :eek:
    OP, if you're supposed to set the 5100's at zero or maybe .85 with the 885's
    How much lift did you get?
    I hope that's not the case, you do look high in the front from pics OP.
  8. Sep 14, 2014 at 7:28 AM
    BORNWILDGUY
    Rich
    Florida
    x2 should be set @ 0 with ome springs
  9. Sep 14, 2014 at 7:34 AM
    StealthTaco
    StealthTaco www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    If you have the bilsteins set at 2.5 with the OME springs then you're probably getting at least 5 inches of lift in the front...your CV boots will be destroyed in a week or two. And I doubt you have a decent alignment...
  10. Sep 14, 2014 at 7:42 AM
    fknayryt
    Bob
    Shorewood, IL
    Few more pics
  11. Sep 14, 2014 at 7:42 AM
    teneighty
    No way it's even close to being aligned if this is the case...
  12. Sep 14, 2014 at 7:46 AM
    fknayryt
    Bob
    Shorewood, IL
    Thanks for the advice. You probably saved me from a lot of expensive aggravation. I'll check the boots. Maybe I do need to lower the front. I got 4-1/2" lift in the front and I was only expecting 2-1/2".
  13. Sep 14, 2014 at 7:47 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :eek:
    Lower it back down to 0. Especially with 885 coils.
  14. Sep 14, 2014 at 7:49 AM
    fknayryt
    Bob
    Shorewood, IL
    I'll scan and post the alignment report. And then I'll lower it back down.
  15. Sep 14, 2014 at 8:24 AM
    teneighty
    Please do...
    Whoa...
    With just the 885's you'll get the 2 1/2" you were looking for.
    You'll find the ride much better as well :)
    Take a pic of your CV angles just so we can make fun of you in time looking back saying, "remember when you were a newb and you set your 5100's at 2.5 with 885's?" Lol
