Selecting a light weight wheel/tire combo (TRD Rock Warriors & KO2s)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crashnburn80, Jul 9, 2015.
  1. Apr 1, 2016 at 3:29 PM
    tdogged
    tdogged New Member
    Tom
    2013 Tacoma TRD Off-Road quad cab short box
    OME lift - 2.5". PTR45-35010 TRD wheels with 275/70/17 Coopers
    Thanks so much! I appreciate that.
    tdogged.
  2. Apr 1, 2016 at 5:03 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Not sure if crashnburn80 has these lugnuts but they are specifically made for those rims: Part # PTR27-89100
    https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-9064
  3. Apr 1, 2016 at 5:08 PM
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
  4. Apr 1, 2016 at 5:11 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    I know Toyota sells TRD lugnuts for the Tacoma but for those rims you definitely have to have those long spline lugnuts or they won't bolt up correctly.
  5. Apr 1, 2016 at 10:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    My 2yr old decided to go for an unplanned swim in a pool today at a birthday party, requiring immediate rescue. After getting home and finally drying off after spending the evening soaking wet in full professional attire, I have zero desire to go out and check the lugs. I'll check them tomorrow.
    ÜberToyota likes this.
  6. Apr 2, 2016 at 9:53 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I pulled mine off and measured the stud depth protruding through the wheel with the depth base of my digital calipers. It is admittedly very difficult to judge visually with how deep the holes are. I had 13.5mm of stud exposed through the wheel, just over half inch. Counting lug rotations I had 7.5 complete rotations before stopping.
    I should have measured the depth of the lug when it was off to see if 1/2" longer studs would fit.
  7. Apr 4, 2016 at 8:34 PM
    tdogged
    tdogged New Member
    Tom
    Have you had a chance to check you wheels out? How much are the lug nuts biting the factory studs?
    tdogged
  8. Apr 4, 2016 at 8:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you not see my above post?
  9. Apr 4, 2016 at 8:36 PM
    tdogged
    tdogged New Member
    Tom
    I saw your reply just now. Thanks.
    Is this enough. I am going to check mine tomorrow and see if the longer studs would work, as this would make me feel better as well.
    Thanks,
    tdogged
  10. Apr 5, 2016 at 8:09 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Toyota lists the wheel as suitable for the Tacoma with the required lugs with no mention of having to swap studs. I'm sure it is safe though admittedly I'd like a little more depth. Let me know on the longer studs.
  11. Oct 11, 2016 at 11:50 PM
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
    I really want to get these wheels, but I can't seem to figure out if they will actually fit on my truck. I have stoptech calipers that stick out around an inch past the hub's mounting surface, so not all wheels will fit. Is there any chance you could give me a rough idea of either the distance between the wheel's mounting surface and the back of the wheel spokes?
  12. Oct 11, 2016 at 11:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just went an measured, significant room. Over 2.5" from mounting surface to back of spoke. Over 1.75" from stock calibers to back of spoke.
    TonyDobbs[QUOTED] likes this.
  13. Oct 11, 2016 at 11:58 PM
    TonyDobbs
    Tony
    Cotati, CA
    Thanks a lot! Looks like I can get my TRD wheels!
  14. Oct 12, 2016 at 12:00 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  15. Oct 12, 2016 at 12:12 AM
    #35
    TonyDobbs
    Tony
    Cotati, CA
  16. Jan 17, 2017 at 8:37 AM
    #36
    Sergio W
    Sergio W Well-Known Member
    Sergio
    Lafayette CO
    2015 TRD PRO
    subd
  17. May 3, 2017 at 7:55 PM
    #37
    Bubbles
    Bubbles Liquor and Whores
    Sunnyvale Trailer Park
    Which 17" cast TRD wheel are you referring to? I'm basically looking to clone your setup and am curious on which wheel you are saying is lighter. @crashnburn80
  18. May 3, 2017 at 8:42 PM
    #38
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Bubbles[QUOTED] likes this.
  19. Jun 7, 2017 at 6:20 AM
    #39
    treejohnny
    treejohnny Well-Known Member
    2016 ACOR
    I really want these rims (PTR45-35010) too, but I am having a problem purchasing them. It looks like Toyota is only selling them as replacements to what came out on your vin. Any suggestions?
  20. Jun 7, 2017 at 7:36 AM
    #40
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Are you buying online or at your local dealer? It seams that happens sometimes at the dealer, but rarely online.
