Serpentine Belt/ Supercharger Belt Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coma17, Jan 13, 2009.
  1. Jan 13, 2009 at 6:08 PM
    Coma17
    Coma17 [OP] New Member
    Mesa, Az
    03 Supercharged PreRunner
    TRD Supercharger, AirRaid Intake, HID Headlights, Custom Mirrors w/Turn Signals, Custom Exhaust w/ Magnaflow, 20" wheels, Tonneau Cover, Roll Pan, Bucket Seats.
    Here is the belt info for an (my) 2003 Supercharged PreRunner.
    A/C Belt - Duralast(from Autozone) - 342K4 4PK0870
    P/S Belt - Duralast(from Autozone) - 420K4 4PK1065
    S/C Belt - Toyota(from Toyota Dealer) -PTR30-35040
    I recently noticed that my supercharger belt was cracking. So, of course I searched TW for any hints, tips, or info on belt numbers and how to's. I found nothing. I ended up just going to Autozone and getting the Power steering belt and the A/C belt and replacing them as well because they had to come off to replace the Supercharger belt. I looked around and found that the Power Steering pump had a tension bolt, so I loosened the mount bolt that locks the tensioner in place, then the tensioner. The A/C had a pulley, which is located below the Power Steering, that also had a tension bolt. I had to loosen the pulley's center spindle bolt to release the tensioner to be able to relieve the tension. Both belts were still a little tough to get off and required a little finess, the help of a flat head screwdriver took care of that.
    Once the A/C and Power Steering belts were off, I used a 3/8" drive breaker bar to release the S/C belt. Then, with a little bit of force, slid the S/C belt behind the tensioner pulley, and manuevered it around the fan and it was out.
    Reverse the process to install!
    dira1987 likes this.
  2. Mar 22, 2012 at 2:52 PM
    MaxN1
    MaxN1 New Member
    Virginia Beach, VA
    03 PreRunner Tacoma
    TRD Supercharger Magnaflow exhaust (new) Drilled front disc brake rotors K&N Air Filter aftermarket grille XM radio ScangaugeII
    Part # of the S/C serpentine belt from the dealer still checks out; $30. Apparently its hard for them to look up, so that could help having it for them.
