serpentine belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redsoxnation, Jul 27, 2011.
  1. Jul 27, 2011 at 5:59 AM
    Redsoxnation
    Redsoxnation [OP] Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Hello... Is it hard to DIY replacing a
    serpentine belt on my 2006 TRD 4x4 ? OEM belt or aftermarket belt?
    My dealer wants $150.00 to do this.. My Taco is 5 yrs old 41k belt looks ok. but taking a long trip in the boonies. figured a new belt would be good piece of mind.. also.. anit-freeze.. anyone replace theirs before 100k reccomnedation? Thanks :help:
  2. Jul 27, 2011 at 6:04 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    The change on the belt isnt that bad as long as you have the routing diagram. I could not find it under the hood or in the owner's manual. Haynes or Chilton manual would be a good investment.
  3. Jul 27, 2011 at 6:09 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    You've got to be kidding me, you mean they no longer put the sticker under the hood with the routing diagram??? :confused: Glad this thread is a heads up on that one..
  4. Jul 27, 2011 at 6:10 AM
    jhodge83
    SC
    i do have caked up mud on the underside of my hood, but i didnt see one on my 07 or the 09.
  5. Jul 27, 2011 at 6:33 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Maybe a little simple green? :D
  6. Jul 27, 2011 at 6:36 AM
    jhodge83
    SC
    ehh...keeps weight on the hood since i dont want that "fake" hood skewp to make it fly off.
  7. Jul 27, 2011 at 6:44 AM
    Pugga
    Massachusetts
    :rofl:
    Keeps the engine insulated
  8. Jul 27, 2011 at 11:46 AM
    Back40
    Back40 Well-Known Member
    SC
    2005 4x4 Dbl Cab
    Simple. Here you go.
  9. Jul 30, 2011 at 1:04 PM
    Redsoxnation
    Pa.
    none yet...
    back 40 Thanks...
    which brand of belt to buy? OEM Gates Goodyear..
    I couldn't find aaplication for 2006 Taco for the gators.. Thanks
  10. Aug 2, 2011 at 8:16 AM
    Back40
    SC
    2005 4x4 Dbl Cab
    I replaced my OEM @ 60k with another OEM. The original still looks good (no cracks) and has been stored behind the back seat just as a backup just in case.
  11. Aug 2, 2011 at 9:24 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make a little diagram before you take off the old belt. Gatorbacks are good, they hydroplane less than the full rib belts. This is handy if you ford rivers and have to go through large puddles frequently.
  12. Aug 6, 2013 at 12:18 PM
    Soltis187
    Soltis187 Member
    08' Tacoma 4x4
    What is the Toyota Part number for the serpentine belt?
  13. Aug 6, 2013 at 1:17 PM
    Sandman614
    Sandman614 Snarky TWSS elf, Travis #hotsavannahdotcom, LRGRNR
    Tim
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    I gots a sticker on my hood of fan shroud showing how it goes.
    Edit: I may be lying.
  14. Nov 5, 2013 at 6:19 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I just replaced the serpentine belt on the wife's 08 4.0L 4Runner yesterday evening. The belt had 86K miles on it and it really didn't look that worn. I replaced it with a Goodyear Gatorback belt. All of the idlers were fine except for one. The top passenger side idler had a tiny bit of wobble to it so I ordered a new Gates 36173 idler this morning.
  15. Nov 5, 2013 at 6:28 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I replaced mine as a precautionary measure after my CV axle boot tore flipping grease everywhere causing my serpentine belt to slip creating a burning rubber smell. Took like 5-10 minutes to replace. I used OEM. Super easy.
  16. Dec 2, 2013 at 11:36 AM
    Ardo K
    Ardo K Member
    Ardo
    Los Angeles
    11 Tacoma TRD Sport 4x4
    TRD Cold Air Intake
    I'm wondering when to change mine i got a 2011 taco 4.0L i have 52k i checked out the belt and it looks good still no cracks what so ever! what do you guys think i usually go to mammoth mountain from LA (about 350 miles) when should i change it?
  17. Dec 2, 2013 at 11:51 AM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    I've replaced plenty of serpentine belts over the years and have only 2 reasons why you'd changed one: 1. It's obviously worn out with cracks or obvious tears etc. 2. You just want to for whatever reason ("piece of mind", squealing, once of these Gators that don't hydro, etc.). It's very uncommon for these belts to just snap or break randomly so if the thing looks fine I wouldn't personally bother changing it, just check it every few months or whenever you do an oil change.
    And in terms of how "hard" it is, you only need one wrench on the tensioner pulley and it'll come right off. Keep track of the correct order with a diagram to make installing the new one easier. Once it's on there and you know the order is correct, let the tensioner pulley back down to tighten it and then do a bump start just to make sure everything is fitted perfect. For those that don't know/haven't heard of this bump start, it's just where you tap the ignition so it spins the pulleys but doesn't actually start the truck. What it does is move the belt around a little so you can make sure it's properly seated everywhere before turning it on all the way and possibly throwing the new belt off by accident cuz you couldn't see one of the bottom pulleys well.
  18. Dec 2, 2013 at 11:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i kinda agree with this guy. i was a delinquent husband and ignored my wife's subaru for awhile. one night she was pulling into the driveway and i heard her belt squeeking..not loud, just a quiet chirp. i took a look with a flashlight and i was STUNNED!! the thing was like ribboned. i have pics somewhere. it was coming apart like string cheese. it held fine. i dont think these things fail catastrophically very often.
    i installed a Gates.
  19. Dec 2, 2013 at 12:01 PM
    Pugga
    Massachusetts
    Change it when it needs changing. If you're worried about the trip, carry a new one with you. I changed mine with over 70k miles on it and only because my idlers were going out anyways.
  20. Dec 2, 2013 at 12:01 PM
    NewRider
    Travis
    '87 4runner
    Working at my last job (jiffy lube I'm sad to admit) I saw plenty of REALLY badly worn belts that REALLY needed replacement but they were still holding. I've only once heard of one just flying apart but that was also a very worn belt being put under high stress while wheeling. The real detriment that happens in these highly worn belt situations is that the belt actually stretches out and can fling debris into parts of the engine, these two things can prematurely wear out other parts like pulleys.
