Service?
Discussion in 'Technical Chat' started by Buckaroo93, Mar 22, 2012.
  1. Mar 22, 2012 at 9:44 PM
    Buckaroo93
    Buckaroo93 [OP] Member
    Ok guys. Don't drop me from the forum after this.
    2003 Tac Dbl cab 4wd 3.4v6
    Bought Aug '07 with 64k
    Currently (Mar '12) 168k
    The only service that has been done on the truck has been reg oil changes, air filters, brakes, tires, etc. I BELIEVE the previous owner had the 60k mile service performed because they said the bill was about $500-$600. I have had NO problems until recently when it feels as though I have a plug fouling (hesitation when under a load) but the "check engine" light doesn't come on.
    What service items do I need to have done in order to get "caught up" and how much is a reasonable amount to pay?
  2. Mar 22, 2012 at 9:55 PM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    Subbed :popcorn: I don't know, but would like to.
    "Irren ist menschlich, vergeben göttlich"
    To err is human, to forgive divine.
  3. Mar 22, 2012 at 10:04 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    If you havent' already done so, you should check out the Toyota Owner's Site, from which you can download Manuals & Maintenance Guides, and check for outstanding Recalls & Technical Service Bulletins (TSBs) on your truck. (Yours should be similar to the one that's attached here.)
    In the meantime, I recommend checking/changing:
    - Timing Belt (and water pump)
    - Spark plugs
    - Lube all drive shaft zerks
    - Transmission, Differential, and Transfer Case oil
    - Coolant
    - Fuel filter
    - Brakes (bleed/replace, as appropriate)
    - Clutch (bleed)
    Cost will depend on how much you're willing/able to do and where you buy the parts.
  4. Mar 23, 2012 at 3:01 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Buckaroo, I agree with everrything Norton has suggested. I expect spark plugs and fuel filter should be at the head of the list, then go completely through the list if it has not been done.
  5. Mar 23, 2012 at 7:07 AM
    Buckaroo93
    Wires or no?
  6. Mar 23, 2012 at 7:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes
  7. Mar 23, 2012 at 4:43 PM
    wolftree
    Rick
    Ohio
    Buckaroo93,
    Yes, I expect the wires and coil packs are overdue as well. I changed my coils and wires on my 98 every other sparkplug change(2X25,000=50,000 miles). Maybe they did not need to be changed then, but I never had a problem with rough running or hard starts in 250,000 miles. Even at 20 degrees below zero.
  8. Mar 23, 2012 at 10:39 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    I had a 1997 3.4l. I would suggest buying a timing belt kit which has a water pump timing belt some pulleys new belts and thermostat. If you pay a garage to the timing belt there will not be much more labor to replace the rest (water pump) as they are already in the front of the engine. The 3.4 is noninterference engine so no big deal if the timing belt breaks but you will be stuck along side the road. I bought a kit off ebay that had OEM part. Mitsubihi timing belt asain water pump ans such.
