shaking in the rear end at take off??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coad11811, Jul 10, 2016.
  1. Jul 12, 2016 at 9:28 PM
    #41
    astott93
    astott93 Well-Known Member
    Austin
    09 Tacoma TRD Sport 4x4
    Bilstein 5100's all the way around.
    I'm having the same issue once I lifted mine. I have the Dakars in the rear. My shimmy is from 0-10 mph. I had all my u joints replaced and my carrier bearing replaced and 600 bucks later it's doing the same thing. When I originally picked it up from the shop it still had the shimmy but wasn't as bad. Then after a couple weeks I was back to the hard shimmy. I put in the carrier bearing drop and it didn't do anything. Anyone rise have any suggestions? Guy at the shop wanted to remove the whole drive shaft and bring it to a place to get it balanced. Trying to do some research before I go that far
  2. Jul 12, 2016 at 9:32 PM
    #42
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    I have learned you could get custom shaft made. However, it's expensive.
    Only other options I know. CB flip, ECGS bearing for the front and rear shims...
    Good luck!
  3. Jul 14, 2016 at 5:26 AM
    #43
    Eric J
    Eric J Well-Known Member
    Ponte Vedra Beach
    2008 MGM dcsb 4x4 Trd sport debadged
    To many to name
    Dose matter about tire size. There mud tires there not supposted to ride good on pavement. There supposted to help u out in the woods
  4. Jul 14, 2016 at 5:26 AM
    #44
    Eric J
    Ponte Vedra Beach
    To many to name
    Dosent*
  5. Jul 14, 2016 at 5:45 AM
    #45
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    I'm not sure if someone posted this but check the carrier bearing on the driveshaft. If the lift is done with an AAL then the geometry is potentially out of spec. You can usually just look at the driveshaft and see if it is not straight. Good rule of thumb is to drop the carrier bearing 1/4" for every inch of lift. So if a 2" AAL is on the truck, try maybe a 1/2" drop and see how it goes.
    Coad11811[OP] likes this.
  6. Jul 14, 2016 at 9:39 AM
    #46
    5150Bronco
    Bay Area, Ca.
    I'm not sure about mud tires being an issue for me. I don't have big mud tires.
    CB is a possible source of remedy but I also read how you should not necessarily mess with CB too. Something to be mindful about.
  7. Aug 23, 2016 at 5:55 AM
    #47
    DrFunker
    DrFunker Well-Known Member
    Could you tell me more about the flip of the CB bracket please?
  8. Aug 23, 2016 at 5:15 PM
    #48
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    what would u like to know??
  9. Aug 27, 2016 at 12:45 PM
    #49
    Vol4life
    Vol4life Member
    2013 Red Tacoma TRD
    I would like to know about the CB flip as well. What does this change? The angle goinging into and out of the CB? Just replaced mine, put on the add a leaf, new 5100 shocks and struts. Still shakes. Not as bad but still there. Thinking of new drive shaft but hate to have the expense and a 4 inch friends shaft creates new issues off road.
  10. Aug 28, 2016 at 5:08 PM
    #50
    tacofish
    N NJ
    14 ext cab 4x4
    My 05 has a spacer lift and bigger tires.
    Never had a problem till toyo did the frame replacement, toyo said drive shaft was bad or was rear.
    replaced both (not buy toyo) still did it.
    Turned out to be all I had to do was flip carrier bearing, cleared it up.
    Could be solution
    That's a sweat looking taco (previous quote from this thread)
    When it did a hard take off or was on took off on an incline there would be a banging noise that you could feel under truck.
    I think it was the drive shaft hitting the tunnel.
    It would do it for a second or two, once I flipped the CB it went away.
    I don't know about angles but I believe the metal bracket on the CB is not centered so when u flip it the CB drops a small amount
  11. Aug 28, 2016 at 6:01 PM
    #51
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    How did you go by flipping the carrier bearings? I am having this problem and been trying to figure out what to do.
  12. Aug 28, 2016 at 6:17 PM
    #52
    tacofish
    N NJ
    14 ext cab 4x4
    This is exactly what mine did.
    The carrier bearing can be good but you should try flipping it over.
    Takes 5min costs nothing.
    Just take out 2 bolts, rotate 180* put bolts back it.
    You don't take out drive shaft.
    quote from post43 this thread
  13. Aug 28, 2016 at 10:19 PM
    #53
    5150Bronco
    Bay Area, Ca.
    Maybe somebody will put up a video for the CB flip question.
  14. Jul 7, 2019 at 3:58 AM
    #54
    TACOMNEWBIE
    TACOMNEWBIE Member
    2009 Tacoma TRD
  15. Jul 7, 2019 at 4:00 AM
    #55
    TACOMNEWBIE
    TACOMNEWBIE Member
    2009 Tacoma TRD
    How do you mean “flip the carrier bearing” like turn it 180 degrees like someone put it on backwards??
  16. Jul 7, 2019 at 4:42 AM
    #56
    JFoffshore
    JFoffshore Well-Known Member
    2011 Toyota tacoma TRD 4x4
    None yet
    The carrier bearing flip just lets the weight of the drive shaft sit on a different part of the rubber that's not worn or broke in. It will do it again once the rubber bushing starts to wear again, the shimmy will return. The angles of the shaft have to be within a .5 degree of its original position stock. Only true way to fix is to correct those angles. 2-3 degree shim in rear depending on height of lift or switch to a ford ranger carrier bearing. I have the HD Dakar in the rear. Needed a 3 degree shim to correct drive angle. I have no vibrations or shimmy at any speed.
  17. Jul 7, 2019 at 7:00 AM
    #57
    TACOMNEWBIE
    TACOMNEWBIE Member
    2009 Tacoma TRD
    Thank you!
  18. Jul 7, 2019 at 4:13 PM
    #58
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Axle wrap, it's gotta be axle wrap......not. You guys kill me. 236 HP and driving like a grocery getter and axle wrap is the answer? You got blocks, it's gotta be axle wrap. Good Lord, get off that one.
    Check that the new wheels are hub centric like they should be. If they don't fit the center raised portion of the rear hub as intended, that may be a contributing factor.
  19. Jul 8, 2019 at 3:54 AM
    #59
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I have an 05 double cab with no lift mod or any other that would change the truck's geometry. I just put on new Michelin standard sized tires and began noticing a take off shutter like the one described.
    This is the second set of tires so I somewhat discounted them and being the culprit.
    After reading this thread and comparing my U joints to another Taco's to find that there is no play in mine, I did the carrier bearing 180* turn and the shutter went by-by.
    I know I am on borrowed time, but at least I have a handle on what was causing the shutter.
    tacofish likes this.
