Shaking while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by irshliquor, Apr 16, 2009.
  1. Apr 16, 2009 at 9:21 AM
    irshliquor
    irshliquor [OP] Member
    Bakersfield, CA
    2009 PreRunner TRD Sport
    When I apply the brakes to come to a stop, it seems like when my auto transmission downshifts it's very shaky. It's either that or the brakes are shaking. Is this normal or does it sound like I've got a problem?
  2. Apr 16, 2009 at 9:35 AM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Had this problem or a similar one start to develop.
    Got my rotors turned and it solved the problem. Check your brakes homie
  3. Apr 16, 2009 at 10:14 AM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Yup, doesn't seem like a tranny problem. I'd start with the brakes. Also maybe get your tires balanced.
  4. Apr 16, 2009 at 10:16 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    I'd wager that you have warped rotors. as stated above, have then turned.
    had this problem on my 97 GMC.
  5. Apr 16, 2009 at 10:49 AM
    irshliquor
    Bakersfield, CA
    Strange - my truck is almost brand new with 5000 miles :(
    Maybe I'll ask the service adviser.
  6. Apr 16, 2009 at 10:53 AM
    brianr
    2010 4x4
    what are your braking habits?
    -splash through alot of puddles, after a hard braking?
    -hit the brakes hard alot?
    -slow down for stop lights at the last second?
    -get on the brakes way too early for stop lights?
  7. Apr 16, 2009 at 10:55 AM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    If you want to rule out the transmission, shift to neutral and then brake. If it still happens, it's your brakes. My money's on warped rotors.
  8. Apr 16, 2009 at 10:56 AM
    irshliquor
    Bakersfield, CA
    I would say no to all of the above.
    I bought the truck with 2553 miles on it (Dealer Demo), so I've only put around 3k miles on it myself. Also, it's done it since day one, but I never gave much thought to it until recently.
  9. Apr 16, 2009 at 11:03 AM
    brianr
    2010 4x4
    there ya go. have them turn the rotors.
    bet it goes away.
  10. Apr 16, 2009 at 11:06 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    If you just bought it, I would take it back to the dealer first and tell them to fix it for free!
  11. Apr 16, 2009 at 11:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How long has it been since you bought the truck?
    You could take it back to the dealer and HOPE they fix the problem.
    Reason I say HOPE - is because brakes are a 'wear' item and they might try to blame it on you & your driving (typical dealer response).
  12. Apr 16, 2009 at 11:53 AM
    irshliquor
    Bakersfield, CA
    Bought it in January
  13. Apr 16, 2009 at 11:55 AM
    JAG
    JAG Well-Known Member
    Just called the dealer for cost estimate because I am having the same prob. $132 out the door. :eek: Can this be a diy??
  14. Apr 16, 2009 at 1:01 PM
    AzPrerunner05
    Tucson
    I feeling these trucks put alot of pressure on the front brakes anyways.
    Needed my rotors turned less than 10k after replacing pads. should have rotated them same time.
    I think you said the truck had 2k on it when you got it. That's 2k of possible hard driving you don't know about.
    Oh dealer demo. Trust me, whenever I go to the Nissan dealer to check out a 350 Z. It's usually to get an adrenaline rush and have some fun. I've bought 1 of the dozens of cars I've test driven. Scared a honda dealer in an Si real good once though...
  15. Apr 16, 2009 at 1:18 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    To avoid warping your rotors, don't stand on your brakes if they're hot. Riding them at all will cause them to get hot. Usually if you're hard on them and sit at a stop light with your foot on the brake, it will cause it. Being aware of your braking habits when you drive will easily prevent this from ever happening.
    Rotors can be turned for a hell of a lot cheaper than that. Go look around at any service, or some tire shops. They'll usually turn them for cheap. All they do is throw em on a lathe and take off a couple mm's. Probably 50 bucks, I had to have a set turned on my old honda when I first bought it, cost me 45 bucks.
  16. Apr 16, 2009 at 2:17 PM
    irshliquor
    Bakersfield, CA
    I just tested it when i went home for lunch. The shaking that I'm noticing is definitely when the transmission downshifts - it seems to shift pretty hard.
    I tried braking in neutral and didn't notice the same shaking.
  17. Apr 16, 2009 at 2:24 PM
    brian
    Elizabeth City, NC
    Ummm... that doesn't sound good, at all. Take that shit in!
  18. Apr 17, 2009 at 7:29 AM
    Raven65
    Camden, SC
    Looks like I lost my bet - which is bad for you because warped rotors are much easier/cheaper to fix than the transmission - assuming there really is a problem with it. Take it back to where you bought it (was it a Toyota dealership?) and let them take a look. If they try to blow you off claiming there's nothing wrong with it, you may have to get a second opinion from another Toyota dealership - and then try to force their hand. Don't be obnoxious about it - but be firm and let them know you're not just going to go away. If it's been doing that since you bought it - they should fix it. If they say "that's what they all do", ask if you can drive another one like it (or go to another dealership if they don't have any) and see for yourself. maybe they do. Mine is a manual, so I can't comment on the automatic.
  19. Apr 17, 2009 at 7:30 AM
    brianr
    2010 4x4
    too bad it wasnt the rotors...thatd been too easy.
  20. Apr 17, 2009 at 10:56 AM
    AzPrerunner05
    Tucson
    No Bueno. Warranty?
