Sheared bolts and rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SomeGuy_GRM, Apr 19, 2022.
  1. Apr 19, 2022 at 5:08 PM
    SomeGuy_GRM
    SomeGuy_GRM [OP] Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    The title should give a good idea what I'm dealing with. Thankfully none of the bolts are super important.
    Does anyone have any tips for removing them. There are no exposed threads. I'm aware of screw extractor kits, but I've never used one.
  2. Apr 19, 2022 at 5:14 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Which bolts? The solutions depend on the size, type and access.
  3. Apr 19, 2022 at 5:16 PM
    SomeGuy_GRM
    Front skid plate, as well as axel brake line mounts. The brake line is zap strapped on atm.
  4. Apr 19, 2022 at 5:37 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Spray down with penetrant for several days. Clean off good and weld a nut to it. It will come out with no issue.
  5. Apr 19, 2022 at 5:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Kearney Rust Cutter or similar products.
    Not WD 40
    6 gearT444E likes this.
  6. Apr 19, 2022 at 5:56 PM
    SomeGuy_GRM
    Some of them are sheared flush and even slightly into the hole. Not sure how I'd weld to that.
  7. Apr 19, 2022 at 5:56 PM
    Shellshock
    Iowa
    Spray them down with pb blaster and let it soak for a couple days. Might want to apply a couple times depending on how bad they are
    I have a tap & die and extractor set I use. It’s gotten way more use than I ever wanted..
    IRWIN Tap And Die Set with Drill Bits, Machine Screw/SAE/Metric, 117-Piece (26377) https://www.amazon.com/dp/B0000DD4KW?_encoding=UTF8
    usually you need to drill at least partially so you can get the extractor something to grab. First couple times kinda suck but once you’ve done the first couple and figure out the process it gets a lot easier
  8. Apr 19, 2022 at 6:00 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Welder and a nut
  9. Apr 19, 2022 at 6:06 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    flush shouldn’t be an issue but if it’s recessed that would be tough, for those I’d drill out with a left handed drill bit then use an extractor.
