Sheared off bolt (step bar install)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vram74, Aug 31, 2017.
  1. Sep 19, 2017 at 8:01 PM
    #41
    vram74
    vram74 [OP] Well-Known Member
    05 Prerunner SR5
    Shit, I’m tired when I get off work. I’ll get around to it one of these days.
  2. Sep 20, 2017 at 2:24 PM
    #42
    devkurf
    devkurf Member at Large
    midwest
    I'm not sure you are going to have a lot of success removing the bolt. I sheared one off, then knocked it up into the body trying to remove it. I dont remember it taking a lot of force for this to happen, but it was 3 or so years ago so I can't really recall.
  3. Sep 20, 2017 at 4:21 PM
    #43
    vram74
    05 Prerunner SR5
    What was your method in trying to remove it?
  4. Sep 20, 2017 at 4:40 PM
    #44
    devkurf
    midwest
    IIRC it went up into the body when I hit it with a center punch, so if you are going to try to use an extractor I would forgo using a punch if possible, and use a good drill bit with minimal pressure.
  5. Sep 20, 2017 at 4:44 PM
    #45
    vram74
    05 Prerunner SR5
    I figured that’s what you were going to say caused it.
    Will probably start with a very small bit and go progressively bigger.
