Shifter Lever moving with bumps in the road.
Discussion in 'Technical Chat' started by Rtd730, Aug 22, 2020.
  1. Aug 22, 2020 at 4:27 AM
    Rtd730
    Rtd730 [OP] Member
    2003 Red Tacoma TRD
    I recently bought my first Tacoma ('03) and besides sun damage to the paint and leaf springs that were maybe at the end of their life everything seemed fine. On the drive home (several hours) I noticed the shifter lever was moving in response to the road. So if I hit a bump on the highway when the front of the truck was coming up, the shifter lever would move forward a fraction of an inch, and vice versa. Has anyone seen this before?
  2. Aug 22, 2020 at 4:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'd guess a motor or trans mount is suspect of being broken
    Rtd730[OP] likes this.
  3. Aug 22, 2020 at 4:29 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Manual? It's normal, although you could tighten the linkage up
    Auto, not so normal, tighten linkage
    Either way, kinda doubt it's a big deal. Others may have more ideas.
  4. Aug 22, 2020 at 4:30 AM
    LoveableWerewolf
    Nashville
    On a truck that old it's possible, quite easy to test too. Trans isn't too bad to replace I believe, engine is a bit annoying.
  5. Aug 22, 2020 at 4:31 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Manual or Automatic??
    My manual shifter moves at times.
    Now if your talking movement of inches it is a different story
    Rtd730[OP] and LoveableWerewolf like this.
  6. Aug 22, 2020 at 4:32 AM
    Rtd730
    Rtd730 [OP] Member
    2003 Red Tacoma TRD
    Haha that seems normal for a manual! But mines an automatic...
  7. Aug 22, 2020 at 4:36 AM
    Rtd730
    Rtd730 [OP] Member
    2003 Red Tacoma TRD
    Thanks for the quick replies! Sorry I should have mentioned that it's an automatic, and that the movement is probably 1/8th of an inch, really only noticable if you are staring or if you are touching it.
  8. Aug 22, 2020 at 6:28 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have noticed on longer trips 4 hours non stop plus 80 degrees temps strange things happen when everything gets heat soaked rubber bushings get softer everything loosens up .
    Then things vibrate at a sweet spot and on different roads .
    If this happens when the truck is parked I might look into this a little more
  9. Aug 22, 2020 at 8:07 AM
    LoveableWerewolf
    Nashville
    If you get under the truck you can wiggle the trans a bit. There should be some play in the mount, but you should be able to tell from checking YouTube if it's normal. Clunking is not. But again listen to above, things do vibrate.
  10. Aug 22, 2020 at 3:16 PM
    Rtd730
    Rtd730 [OP] Member
    2003 Red Tacoma TRD
    I went out and tested the engine mounts by reving in drive and did not see any significant movement (or anymore than the YouTube video suggested was normal) in the engine. The transmission mount can be compressed about 1/8" squeezing it with one hand. The carrier bearing moves more when I push up on the center of the driveshaft.
    Today while driving around I noticed that I could also make the shifter move by accelerating quickly.
    I'm considering replacing both the mount and the carrier bearing beacuse I also occasionally feel a knock after stopping quickly and I'd rather deal with now.
  11. Aug 31, 2020 at 8:23 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    My 02 did this it’s whole life it’s a non issue.
  12. Sep 1, 2020 at 1:27 PM
    perchalot
    perchalot Well-Known Member
    San Diego
    2020 4X4 OR DCSB, 2014 DRZ400SM
    The knock after stopping, then releasing the brake is from axle wrap. The moving shifter is the trans mount. Both very normal on a 1st gen. Both also related to the slip yoke on the driveshaft. Very hard to lubricate via the zerk. I used to remove and disassemble mine, coat with Motorcraft PTFE grease, and it would go away for a couple months, then return.
    The 1/8” movement you describe is not concerning. Annoying, yes.
    Rtd730[OP] and gotoman1969 like this.
  13. Apr 27, 2021 at 1:33 PM
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    Just had new rear springs put on mine this morning. Asked them to look into the same issue you have posted as well. Shop owner took it for a test drive and noticed the shifter movement. Once he has a lift open again, he's going look closer and see what it could be.
    I'll know more in an hour or so.
  14. May 9, 2021 at 11:56 PM
    GoPedTed
    GoPedTed Member
    2002 TRD 4x4 Dbl Cab
    Shifter bushings. Cheap fix and a hours time. Plenty of vids showing how to do.
    EMC, gearcruncher and Dan 77 like this.
  15. May 10, 2021 at 1:42 AM
    gearcruncher
    Canadain bumper technician
  16. Sep 21, 2022 at 1:17 PM
    EMC
    EMC New Member
    98 4Runner 3.4 L 6cyl
    My 98 auto 4runner was also having this problem. Turns out one of my sway bar bushings was broken. Seemed to fix the problem.
  17. Oct 6, 2022 at 4:26 PM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    +1 to this. Also look at the center support bearing. I had the issue bad enough that the shifter would move enough to take the truck from drive to neutral. Happened off-road when the rear suspension would cycle rapidly over a large range. I replaced the transmission support, center support bearing and did the slip yoke disassembly cleaning/lubrication and the issue went away. It looks like the slip yoke was binding slightly, which when combined with the old center support and transmission mount, would force the transmission to move enough to force it into a new gear selection.
  18. Oct 10, 2022 at 4:34 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Just saw this and wanted to chime in. My 02 has done this since the day I drove it off the lot. Just a few days ago, I tore down the AT shifter assembly (in process of a swap to 4WD). My shifter bushings were not brittle nor falling apart. I replaced them anyway but have to say those 20 yr old bushings were in decent shape.
