Shifter stuck in park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by the dude man, Dec 30, 2013.
  1. Oct 23, 2017 at 5:32 PM
    Mcsosgt110
    Mcsosgt110 Well-Known Member
    Northern California
    2016 Trd offroad
    In the works
    My 2016 dcsb offroad was stuck in park. Used over ride button. All fuses good. Brake switch good. Actuate r solenoid good. I was stumped. I cleaned my negative post on the battery terminal and that appeared to be the problem. Something to try. Has been working for over a month now. Just another possibility.
  2. Oct 28, 2019 at 4:14 PM
    FrostyEldin
    FrostyEldin Well-Known Member
    Austin
    Lewiston, ID
    2008 SR5 Impulse Red
    I have to use the override switch every time i pull out of park, and I have also noticed when I use my cruise control and apply brakes that sometimes the light starts flashing and sometimes it stays solid like it is supposed to.
  3. Oct 28, 2019 at 10:14 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You have an intermittent brake switch.
    FrostyEldin likes this.
  4. Oct 29, 2019 at 11:40 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Whats with all the BANNED guys on this thread ?
  5. Oct 29, 2019 at 8:38 PM
    lynlan1819
    Tacoma
    Lifted
    O.P. did you get your truck fixed ?
  6. Oct 29, 2019 at 9:51 PM
    Muddinfun
    Muddinfun Well-Known Member
    The OP boogied in 2014, just 28 days after he started this thread.
  7. Jun 23, 2024 at 6:16 AM
    tha_roost
    tha_roost TX YardBird
    Ry
    Deep East TX
    03 PreRunner CrewCab TRD SR5
    DIY Installations: • Pioneer DMH-W2770NEX Wireless AA Head Unit • OEM Cruise Control, CC Selector Lever Steering Column Mod & CC Stop Lamp Switch Swap • Drivers Power Window Control Reversal • TVIP Security System - New Remote Programming • Muffler Tip Upgrade • 2019 Tacoma Rims/Tire Swap • Reverse Bulbs LED Swap • Cloth Seats Reupholstered w/Med. Oak Leather Grain Vinyl DIY Repairs: • Collapsed OEM Tokiko Rear Shocks Replaced w/FOX 2.0 Shocks • Drivers Side Rear Axel (Seals, Bearings, ABS Tone Ring) • Differential (Flush, Breather & Drain Plugs) • Wheel Hub (Gaskets, Studs & Nuts) • Drum Rebuild (Backer Plate, Cylinders, Springs, Shoes, & Lines) • Parking Brake Calibration • Stop Lamp Switch Replacement • Drive Belts • Propeller Shaft Joints Greased • UV Dye Test Engine Oil Leak
    I suspect exactly what you're describing is happening to me.
    What I know:
    • Im pretty sure my booster has a small vac leak because when depressed and then pushing harder than normal I hear a whistle.
    • on a handful of occasions when I've had to panic brake the pedal got really hard, but the truck was barely slowing down. This primarily happens when accelerating from a full stop and then rapidly switching from accelerator to brake pedal.
    • the brake light switch bumper/stopper (little plastic piece that holds the brake light switch in when not pushing brake pedal) broke and I couldn't find one anywhere near me so I taped a few pennies together and then to the place where it snaps in and it fixed my brake lights staying on even when the truck was off and no key in ignition
    • I recently decided to install Toyota OEM Cruise Control. After doing extensive research I was pretty sure my truck just needed the cruise switch to work. Bought it, plugged it in and mounted it...got a green flashing "Cruise" on the dash. Remembered reading that the brake light switch might need to be swapped with the cruise version, but again couldn't find a Toyota OEM one anywhere near me so I bought 1 of only 2 aftermarket ones available nearby. The one I bought looked exactly like the Toyota one. Installed it and the flashing "Cruise" was now a constant "Cruise". Took it for a test drive and tested all of the functions and it works. The only thing that didn't seem to work all the time was the memory recall function. If I use the cruise lever to "Cancel" a set cruise speed, I only have about 5 seconds to "Resume" before it won't resume the last set speed. If I use the brake pedal to cancel a set speed it won't resume the speed no matter how quickly I do it.
    I installed it about 2 months ago and had no issues with it, but just last week I was cruising at about 70mph and tried to push the brake to release the cruise, but it wouldn't let me push the brake and felt similar to how I described above that I had attributed to a booster leak. It's only done this the one time. Since then several times that I've had the cruise on and then put the truck into park or reverse after I've been driving using the cruise, the dash indicator will start flashing and I have to turn the cruise off and back on to work again. The most problematic issue that started the same time as the flashing recently is that the 4 speed auto floor shifter has been getting stuck in Park. I noticed it usually does it if I don't fully depress the brake pedal, slowly and wait about 1-2 secs before pushing in the shift release button before attempting to shift the lever. If I try and do it too fast or don't have the brake all the way pushed in before attempting to shift or whatever then it locks up. Happened in a Whataburger drive through line last night. I wonder if swapping the brake light switch for an OEM one and/or replacing the booster will make a difference.
