Shifting from neutral to reverse while driving..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Aug 17, 2010.
  1. Aug 17, 2010 at 10:27 AM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    What is the most damage this can cause my truck? I sometimes like to roll the truck down hill on neutral, but it's always been a fear of mine to accidentally shift it up again to reverse. Anyone ever experience this crucial mistake?
  2. Aug 17, 2010 at 10:29 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Just leave it in drive so you don't have to worry. And it wont do anything anyways, the computer wont let it shift into reverse while your driving forward.
  3. Aug 17, 2010 at 10:39 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    I don't do it to save gas, I do it to have more control of the car especially if I want to brake quickly.
    TacomaEd15 likes this.
  4. Aug 17, 2010 at 10:47 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I was in a Toyota sedan one time and was doing about 90 mph on the frwy and knocked the shifter into reverse and nothing happened.......I would think they make some kind of override that prevents any damage.....
  5. Aug 17, 2010 at 10:47 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    You should have the same amount of control whether it be in drive or neutral. Also braking should be the same while coasting in drive or neutral. It's a matter of how quickly you can move your foot.
  6. Aug 17, 2010 at 10:49 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    x2, just leave it in drive.
  7. Aug 17, 2010 at 10:49 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    So it's probably best if I never slip it onto neutral, correct?
  8. Aug 17, 2010 at 10:50 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    its not hurting anything, just unnecessary.
  9. Aug 17, 2010 at 10:54 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    This is not entirely accurate. The engine consumes fuel every time the spark plug fires, throttle open or not. It is the same amount of fuel as if it were idling. that being said, if you downshift with the throttle closed, the engine will turn higher revs, so that small amount will be injected more often, thus using more fuel than just idling.
  10. Aug 17, 2010 at 10:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    why does the scangauge goes to 999.9 mpg when engine braking?
  11. Aug 17, 2010 at 10:59 AM
    JDMcQ
    Because it is wrong. Seriously, it is wrong. Your fuel economy does go up dramatically, with your foot off the accelerator, but does not go up to infinity. Perhaps the programming doesn't allow it to calculate that small of a a fuel flow.
  12. Aug 17, 2010 at 11:00 AM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    The car salesman said that my 2010 Tacoma will go into neutral if placed in reverse if over 30 MPH but 30 MPH and below it will go into reverse.
  13. Aug 17, 2010 at 11:00 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    haha, alright. Makes sense.
  14. Aug 17, 2010 at 11:00 AM
    JDMcQ
    That may be true, but if they are cut off for too long, the engine will stop running.
  15. Aug 17, 2010 at 11:04 AM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Do not roll downhill on neutral. You are cutting off the transmission cooling. You will damage it.
    edit: It doesn't. My bad. Still bad when you shift into drive tho.
    As for shifting Reverse from Drive. While driving the computer will not let you. But when you are making quick shifts from D to R like a lot of people do in winter to get unstuck, doing the rocking manoeuvre manual trannies can do, it can break your auto transmission very fast. Always wait for a full stop before shifting from D to R or vice-versa. You are not driving a manual!
  16. Aug 17, 2010 at 11:05 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    You should have asked them to do a demonstration.
    Sidney Vicious likes this.
  17. Aug 17, 2010 at 11:07 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Uhhhh what? I'd rather have the help from my engine to help me stop versus relying just on the brakes.
  18. Aug 17, 2010 at 11:07 AM
    JDMcQ
    Well, that is interesting Christian. Thank you for the info.
  19. Aug 17, 2010 at 11:08 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    How so? Even when going downhill in San Fransisco!? Not that I live there, but driving there was pretty difficult.
  20. Aug 17, 2010 at 11:10 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    my dumb gf put my truck in reverse thinking it would be funny, nothing happened. The truck gets put out of gear and you just coast. I still got pissed at her anyways. When I was trying to shift to neutral on my '78 silverado I got reverse and had to replace the axle. It threw a tooth off the diff gear and through the housing.
