Shifting from neutral to reverse while driving..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Aug 17, 2010.
  1. Aug 17, 2010 at 11:12 AM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    ^^Haha ya my gf sometimes shifts it from drive to neutral and that scares me sometimes too. Good to know that there is no real danger.
  2. Aug 17, 2010 at 11:23 AM
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    Does it matter if you are in neutral? just currious.
  3. Aug 17, 2010 at 11:46 AM
    mandzach
    mandzach Well-Known Member
    It's amazing to me...how many idiots drive Tacomas.
    Engine Braking :confused:
    Auto Transmission Cooling :confused:
    Hate to be negative but some of you guys have the mechanical knowledge of a 4 year old girl.
  4. Aug 17, 2010 at 11:54 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    wow...
  5. Aug 17, 2010 at 11:54 AM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Yeah, thanks for your constructive post.
    I was mistaken. You still drive the pump while coasting. It's more putting it back in D that can be really harmful.
    Also:
    http://www.caranddriver.com/feature...to_a_stop_2c_do_not_shift_into_neutral_page_3
  6. Aug 17, 2010 at 12:39 PM
    mandzach
    Actually ya, I heard of them when I was like 11 or 12.
    Guess my sarcasm was lost in translation.
  7. Aug 17, 2010 at 1:19 PM
    madjohnbo
    madjohnbo Member
    Great Falls, MT
    '10 DC 4x4 SR5 Black Sand Pearl
    I had a 1997 Ford Taurus and accidentally shifted into reverse while coasting down a hill. It cut the engine and I about flipped out because I though I'd broken it. It started right back up. It must have had a kill switch or the computer did it.
  8. Aug 17, 2010 at 2:13 PM
    sabu
    sabu Squirrel Driver
    Ron
    So. Cal.
    MG 4x4 TRD OR AC
    XM Radio, Redline hood lifts, X-tra bed tie-downs
    I find coasting down hill in drive more controlled than when in neutral. I often downshift to 4, and sometimes 3, to get better control. There is significant engine drag, even with an auto. More control and cooler brakes.
    I have very little concern about transmission trouble. It' a Toyota.
  9. Aug 17, 2010 at 2:18 PM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    I remember doing it to my dad's ' 65 Chrysler. I don't know how much or little damage it did, but the massive clunk sound wasn't pretty.
  10. Aug 17, 2010 at 2:38 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    My friend did it in a f-150 going about 30 mph. The truck lurched and the tires squealed. Don't remember if it stalled or not. I was pretty freaked out at the time. The truck is still alive and well 3 years later
  11. Aug 17, 2010 at 2:54 PM
    copernicus
    copernicus Well-Known Member
    Looks like you just pointed yourself out.
  12. Aug 17, 2010 at 3:23 PM
    JKD
    JKD Well-Known Member
    How does taking it out of gear give you more control over the vehicle? That takes away both throttle input AND engine braking.
  13. Aug 17, 2010 at 3:26 PM
    JKD
    A 1965 Chrysler would have had a Torqueflite transmission. Reverse was locked out by hydraulic control at speeds above 3-5 mph.
  14. Aug 17, 2010 at 4:03 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    Interesting some people convinced themselves that they have more control of their vehicle while in Neutral then in a gear in a coasting situation
    Crazy also because you can get a ticket for it in Washington State, with the issue being stated as "operator has no control over vehicle"
  15. Aug 17, 2010 at 4:15 PM
    #35
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    As stated before, do NOT coast in neutral with an auto transmission (manual is fine). Only put it in neutral to coast as an emergency event (aka prius out of control situation).
    The way an auto works is by having fluid do the transfer of power from the engine to the gears, through the torque converter. This is also why you can't (rather shouldn't attempt) to start an automatic by doing a rolling start. It's a great way to ruin your transmission. If you're in neutral, the torque converter is still spinning as it's directly bolted to the flywheel on the engine, but it's not moving the fluid through the transmission allowing it to cool.... so all that fluid in the torque converter is rapidly heating up and unable to cool (usually a few quarts worth).
    You can probably get away with it for awhile, but the more you over heat the oil, the less it will be able to do it's job to properly lubericate and protect the parts in the transmission. Not worth it.
    Also, in most states it's illegal to do this anyway. Arizona is one of them. Coasting in neutral (auto or manual) is considered that you have the vehicle in an 'out of control' situation, if you were to wreck in that state you could be found at fault. Not worth it.
    As for having more control in neutral... that doesn't even make sense. The only possible thing for this I can get is you two foot and use left brake and right gas. If you are, stop doing that... it's very dangerous and a horrible driving practice.
  16. Aug 17, 2010 at 5:23 PM
    #36
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I drive a 5 speed so my situation is different, but I coast in Neutral constantly. You gain so much more momentum when going downhill...it's free acceleration.
  17. Aug 17, 2010 at 5:51 PM
    #37
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Shift to a lower gear and use engine braking. The owner's manual even endorses it. On heavier trucks it's the only way to slow safely downhill - slam the brakes first and you will jack-knife.
  18. Aug 17, 2010 at 5:59 PM
    #38
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My truck shuts off if I am rolling forward and it ends up in Reverse. Trust me.
  19. Aug 17, 2010 at 6:02 PM
    #39
    Dimonback
    Patrick
    Didn't know that. Maybe it was my '66 Mustang...? And maybe I went into Park... LOL... must be my Oldtimer's kicking in.
  20. Aug 17, 2010 at 10:13 PM
    #40
    Karo
    Karo
    La Crescenta, CA
    Grill
    Well the way I see it, when the vehicle is taken off from any gear and left on the velocity of which the slopped zone provides, through gravity, THEN I have full control of how fast I can hit the brakes when a dog crosses the street or a kid throws a ball into the street. I also think its a better way to drive especially when coasting down an residential street. You might accidentally get side-tracked and hit the gas pedal than the brakes when needed. That's really the only time I like to drop down to neutral.
    I don't accelerate to 80 on the freeway and punch it into neutral, if this is anyone's idea of coasting.
