shifting into reverse noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flygirl, Oct 14, 2011.
  1. Oct 14, 2011 at 4:53 PM
    flygirl
    flygirl [OP] Active Member
    ct
    2013 Tacoma TRD Sport Access cab
    on my 2009 Tacoma , lately when I stop, shift into reverse...when I start moving I hear a loud metal sound as I step on/off the brake......thoughts on what this could be ? Please be kind , hopefully not a big problem & I thought I would ask here before asking the stealership
  2. Oct 14, 2011 at 5:05 PM
    saugus
    saugus Well-Known Member
    I have that when I don't take the extra time to shift firmly and make sure it locks into gear.
  3. Oct 14, 2011 at 5:17 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    From what I understand it's just the brake shoes/pads re-seating. Mine did it for awhile when backing out of the driveway but doesn't do it anymore.
    read below links...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/180299-clunk-when-backing-up.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/72930-terrible-noise-when-i-move-reverse.html
