shit happens
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03aztaco, Jun 2, 2011.
  1. Jun 2, 2011 at 10:09 PM
    03aztaco
    03aztaco [OP] Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    so about 8 miles in the desert with some buddys my third meber decides to take a shit and reverse was my only gear untill it shaved some more gears down for drive. i had 4.10 stock tacoma gears in there but when somthing breaks its a sign to me it needs to be bigger and better:cool: so im have 4.88 put back in but anyways heres the damage ill post pics after the rebuilt is done repair 040.jpg
  2. Jun 3, 2011 at 3:49 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Out with the old:(/in with the new.:D
  3. Jun 3, 2011 at 4:06 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    FWIW 4.88 gears are actually the same strength maybe weaker than 4.10s since the teeth need to be thinner for the extra teeth. 4.56 thick are stronger though
  4. Jun 5, 2011 at 3:02 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Roland is correct on this this. 4.88 are weaker because the teeth are thinner. Even though there are more teeth, the thickness of the teeth is a big difference compare to stock.
    I went through eastcoastgearsupply.com and got nitro gears. They gave me a 5 year warranty on a built third member.
  5. Jun 5, 2011 at 11:47 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Sorry mine didn't work out for you... but hey it all worked out for the better right? ;)
  6. Jun 6, 2011 at 5:11 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    ya it will be done wendsday
  7. Jun 6, 2011 at 6:33 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    How much are you paying if you dont mind?
  8. Jun 6, 2011 at 8:24 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    i do mind......no im just playin 650 for everything seals rebuild and all but i dropped it my self if he had to do it im sure it would have been a few hundred more
  9. Jun 6, 2011 at 8:26 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    ya but i was told with the 33s i shout run 4.88's he said no matter what gears i have ill do the same thing but who knows he gave me a warranty so well test them out im just sick of the lag from the larger tires
  10. Jun 6, 2011 at 8:50 PM
    acidfly
    Kevin
    Kitsap, Wa
    Is it recommended to do front and rear gears or does it.matter?
  11. Jun 6, 2011 at 9:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    the OP is a prerunner so he doesn't have a front diff. If you are a 4x4 you got to change both.
  12. Jun 6, 2011 at 9:27 PM
    acidfly
    Kevin
    Kitsap, Wa
    Damn..... expensive
  13. Jun 7, 2011 at 12:30 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    part of the reason im happy with 265s...
  14. Jun 7, 2011 at 6:21 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    What kind of pre existing noises were coming from your rear diff before it grenaded on you ?
    Mine is getting ready to take a shit , pinion bearing is howling, whining like hell (although I've seen diffs make this noise for years without exploding)
    Since I gotta pull out the third anyway to change bearing, prolly let a reg. shop do it so's they set the pre load on pinion & all that touchy shit...
  15. Jun 7, 2011 at 6:25 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
  16. Jun 7, 2011 at 6:43 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    Are you locked out back?
  17. Jun 7, 2011 at 10:12 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    ya i have the e locker when i want it but only used it once in 3 years
