Shop Builds?????
Discussion in 'Garage / Workshop' started by Steve J, Dec 6, 2011.
  1. Jan 24, 2012 at 4:05 PM
    Steve J
    Steve J [OP] Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Avid front light bar, Avid bolt on sliders, Avid rear bumper protector, T-Rex grill & bumper insert. Still lots to do though.
    Galvanized is the norm, but I just wanted the drops in copper & decided to just do the whole thing in cpopper. Sad thing is that all the copper on the ceiling is going to get burried uder the surface mount drop ceiling that I am going to do.
  2. Jan 24, 2012 at 6:32 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    hmm, ..i'm a bit puzzled why you want a drop ceiling... looks like you've already got a bunch of overhead lighting and overhead storage, ...you'll lose that w/ the drop ceiling, including losing interior space, let alone all the work to do it :confused:
  3. Jan 25, 2012 at 6:30 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Ewwww ...please don't do a drop ceiling. You'll regret it later.
  4. Jan 25, 2012 at 7:18 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    I am doing a SURFACE mount drop ceiling. I'll only loose 1.5 inches. The thing is, the master bedroom is right above the garge. I need to deaden the noise from the garage so I don't disturb the wifes sleep while I'm in the garage & I am going to put a bit of insulation between the ceiling & drop ceiling to absorb some of the heat when a car is parked in the garage. Right now, you can tell a difference in the bedroom when a hot car pulls in to the garage. Since I am in Canyon Country, it gets warm enough during the summer time.
  5. Jan 25, 2012 at 7:32 AM
    macgyver
    Brad
    Canton, GA
    Insulation will help a ton. My garage is a lot cooler in the summer time since I've insulated the ceiling and the garage door. Is there insulation in the joist bays currently?
  6. Jan 25, 2012 at 7:37 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    No insulation in the joist bays at all.
  7. Jan 25, 2012 at 7:41 AM
    macgyver
    Brad
    Canton, GA
    If I were you. I would pull the drywall down off the ceiling and insulate those joist bays. You'll get a much better R-value and noise reduction than 1.5" of rigid foam ever will.
    That's only about $100 worth of drywall and $30 worth of mud and tape. Go rent a drywall lift for a day ($50) and have a buddy help you. You should be able to knock out the garage in a few hours. Not to mention you won't have to do a drop ceiling. Also, you will be able to run any piping and electrical under the drywall.
  8. Jan 25, 2012 at 7:45 AM
    Pnicholas1019
    Pnicholas1019 Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    Sweeet looking garage i like those tool box/work benches you have im looking for something similar.
  9. Jan 25, 2012 at 7:55 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Hey Macgyver, I would & have thought about it, but I do small part powder coating on the side & can't really hold out any longer on that to do the insulation & drywall let alone having all the drywall dust floating around while I powder coat. That just doesn't work out very well.
    Pnicholas1019, The boxes came from Sams Club just over $400 each.
  10. Jan 26, 2012 at 7:04 PM
    ManMan
    ManMan Well-Known Member
    Here's my on-going shop build! I put up the building early in 2011 and have been slowly adding power, lights, paneling, etc. Also going to be putting in some overhead storage in the corners. It's a 24x40x12 with 16x10 front door and 10x10 door in the back.
    Excuse the mess, but the shop itself is a work in progress, and it contains several works in progress!
    Just put up the paneling in the back right-hand corner that will be my work benches and tools. Got the sockets in but not connected to the breaker yet, ran out of romex
    Looking towards the loosely organized front. Chemical cabinet, lawn equipment, and some heavier machinery
    Towards the back down the other wall, storage, and oven for powdercoating
  11. Jan 27, 2012 at 7:15 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Hey ManMan, I am seriously jelly here. Wish I had that much space. It is rough trying to do all I need to in my small garage. I will post pics of some of the other stuff I am doing in my garage a little later today. If I had the space you have, I would have my own powder coating business going on.
  12. Jan 27, 2012 at 7:51 AM
    ManMan
    Having enough space to build a shop was a priority when we bought a house. We really lucked out on several things that made getting this house and shop possible!
    At one point I lived in a apartment and my "shop" was a tiny coat closet that I had built a work bench into!
    As soon a get more power run and some practice, I am going to start doing powder coating on the side. I'll probably have to break down and buy/build a blasting cabinet as well instead of my blast from a bucket setup!
  13. Jan 27, 2012 at 8:07 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    Right now I powder coat small parts as I do not have a big enough oven. Mostly doing motorcycle parts & what not. I am doing what I can with what I have for now. I just shot some Kawasaki Green on some KLX 450 parts last night. I'll get some pics up soon.
    Side note, I see you like riding bikes. 2 SV650's huh. I have a Ninja 250 & a FJR 1300, both for me.
  14. Jan 27, 2012 at 11:10 AM
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    A little late with the pics but here they are. It is my make shift spray booth for the powder coating. It is a make shift refridgerator. I pulled all the machanics out of it. There is nothing but the shell left. I cut a couple holes in the back of the fridge portion & installed a couple fans to pull the dust that are covered in filters. It is framed in behind the fridge with wood & aluminum panel with an exhaust port that is also covered in a filter.
    Inside of doors shelves removed & sheeted. Couple hooks on the door to hold tools & a light mounted to door for lighting.
    Closer look inside, the hanging rods the original holes covered & my exhaust vents
    The freezer portion is pretty much a clean area to let the parts cool down. I cut in an exhaust for it if it is too hot in there.
    Here is a view of the filtered intake that I cut in to the freezer portion to flow air over the cooling parts.
    Last night I shot some Kawasaki Green on some KLX 450 parts for a neighbor. It doesn't look like a match in this pic, but on the bike, it's a perfect match.
    I am working small parts only due to my oven is a small kitchen convection oven. Still trying to find some space for something a bit bigger.
  15. Jan 27, 2012 at 10:22 PM
    #35
    wileyC
    Centerville, OH
    cool, good use for an old refrigerator!:cool:
  16. Jan 27, 2012 at 10:27 PM
    #36
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    thats a nice air setup youve got Steve J!
  17. Jan 28, 2012 at 7:36 AM
    #37
    ManMan
    I dig the fridge idea! I may have to steal your idea
  18. Jan 28, 2012 at 5:34 PM
    #38
    Steve J
    Canyon Country Ca
    12 Access Cab 4x2
    I've had quite a few people hit me up about the fridge idea. It's great for storing most of my suplies as well due to it's pretty well insulated as well. It's amazing what you can come up with for ideas when you are on a budget.
  19. Jan 29, 2012 at 8:58 AM
    #39
    ManMan
    I was going to build mine out of PVC pipe and heavy canvas drop cloths. But I think the fridge will be cheaper AND more durable!
  20. Jan 29, 2012 at 9:02 AM
    #40
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Yup. I'm totally jealous of your garage.
