Shopping list for 1" lift, first gen
Discussion in 'Suspension' started by Leadgolem, May 25, 2010.
  1. May 25, 2010 at 12:30 AM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I'm making up a shopping list for a fairly conservative lift and wanted to know if I left anything out. I'm planning on setting the billies to 1.75
    Bilstein 5100's front and rears.
    http://www.toyteclifts.com/index.ph...ategory_id=63&option=com_virtuemart&Itemid=72
    Rear shackle lift 1"
    New rear bushings
    New front bushings
    I'm curios whether I would need axle shims or a suspension drop kit with such a conservative lift. Also, I'm wanting to address some driver side lean when I do my lift. Any advice on how to do that?
  2. May 25, 2010 at 12:37 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    so you just wanna get rid of your rake right?
  3. May 25, 2010 at 12:44 AM
    Leadgolem
    Greg
    Littleton, CO
    That's the general idea, but I also want a little bit of lift so I don't rub my tires making my crazy turn into the driveway. :) They're only 31x10.5 but I have to compress my suspension at near lock to pull in.
    The driver side lean I'm talking about is just that. The truck is higher on the passenger side then the driver side.
  4. May 25, 2010 at 12:48 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Gotcha, Billys set at 1.75 will do the trick and as for the taco lean...getta spacer for the driver side. a 1/4" should take care of it :)
  5. May 25, 2010 at 12:49 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  6. May 25, 2010 at 1:02 AM
    Leadgolem
    Greg
    Littleton, CO
  7. May 25, 2010 at 1:03 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  8. May 25, 2010 at 8:59 AM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Looks like we got the same shopping list.
  9. Jul 11, 2010 at 3:23 AM
    Leadgolem
    Greg
    Littleton, CO
    Just wanted to do a sanity check. For my intended lift I should set the snap ring on the front shocks to the middle groove, right?
  10. Sep 2, 2010 at 11:19 PM
    Leadgolem
    Greg
    Littleton, CO
    For anyone who is interested my lift is complete.
    If I were going to do this again I'd do an aal lift on the rear instead. I chose a shackle lift because it was supposed to be easier. It wasn't. The bushings on the rear where completely fused to the shackle. I had to use a torch to get them out. Plus, with an aal lift you'd get the additional weight capacity.
    The front was much easier then I expected. Took about 4 hours for me. Not bad since I've never done anything like that.
    Prior to lift the difference between the top of the tire and the bottom of the wheel well front to back was 1.89 in. Post lift the difference is 1.125 in. Since the rear got a straight 1 in shackle lift that means I've gotten 1.765 inches of lift on the front. Contrary to what I posted above the middle ring setting on a first gen, there are only 3 setting on the first gen shocks, is supposed to be 1.25 in. I've double checked my install, my install is correct. I'd credit the difference in the shock it's self. The front shocks where completely shot. I'm fairly confident these were the original factory shocks.
    All in all, I'm very pleased with the new height of my truck. The ride is excellent, especially compared to having no functional shocks on the front. :)
  11. Sep 5, 2010 at 8:46 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    How are people getting 5100's for a 1st gen and setting them to 1.75"? Mine only came with 3 - 0", 1" and 2.5".
  12. Sep 6, 2010 at 8:08 AM
    3fitty
    3fitty Well-Known Member
    Lambone
    Gulf Coast
    01 Prerunner
    Bilstein 5100 front, 5125 rear and Skyjacker AAL. Manaflow Catback exhaust. aFe Pro-Dry air filter.
    Yeah, AAL would have been a good choice. I just finished my lift also. 5100's up front at 2.5 with some Skyjacker AAL out back. I didn't take any measurements before the install so I don't know how much lift I got. There's still a slight rake so I'm guessing the AAL lifted the rear about 2 inches. The unexpected benefit I got from the AAL was the disappearance of my axle wrap :D :D . It's not 100% gone but probably 99%.
  13. Sep 7, 2010 at 11:02 AM
    Leadgolem
    Greg
    Littleton, CO
    You don't. Settings on the 3 groove shocks are 0, 1.25, and 2.5. That's the over stock settings. If your front shocks are toast you get about another half inch over actual, since you now have working shocks too. Over original new truck ride height it's still 1.25.
  14. Sep 7, 2010 at 4:20 PM
    96er
    96er Sport Rally'er
    MA
    I'm 7/8" higher in the rear than in the front. Getting fronts set to the middle groove, do you think I'll have a noticable bro lean? I really only see that when guys do 2.5" on 1st gen fronts, so I think I'll be ok, no?
  15. Sep 20, 2010 at 7:26 PM
    Leadgolem
    Greg
    Littleton, CO
    Sorry I'm late getting back to you. No, I don't think the "bro" will be to bad. It's less then 1" then you should be fine. Based on your front to rear difference it looks like you have working shocks on the front so you would be getting 1.25 over your current height.
    My rake was a lot more extreme due to the blown front shocks before the lift.
    It will me much more noticeable if you've got the bed loaded though.
  16. Sep 20, 2010 at 7:31 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Dang my shopping list also. I just got the bilsteins so I can mark them off the list.
  17. Oct 1, 2010 at 2:45 AM
    Leadgolem
    Greg
    Littleton, CO
    I'm surprised nobody called me out for being stupid on this one. The shocks are not load bearing. Therefore the preload on the spring is what gives you the height. 1.75 is a result of compressing the spring. The distance compressed is about 3/4 of an inch, but that is enough to actually lift the truck 1.75 owing to the relative spring rate and the truck weight.
    Sorry for being a dipshit...
