Shops to grease yur zerks!
Discussion in 'North West' started by 20somethingwidataco, Dec 8, 2018.
  1. Dec 10, 2018 at 8:27 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    I had like 5 or 6 between the two driveshafts on my 2008 4wd
  2. Dec 10, 2018 at 8:37 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    FYI I recently saw on my local FB tacoma groups where several guys had total driveshaft failures at the U joint and they never greased them. It’s probably the most commonly overlooked basic maintenance item on the truck
  3. Dec 10, 2018 at 11:30 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Yup I saw that too. It's what lead me to this lol. To my knowledge it's been 30k miles. So it's time but not too overdue. Will likely have it taken care of in the next two weeks
  4. Dec 12, 2018 at 2:46 PM
    20somethingwidataco
    Will
    Washington State
    I'll probably be leaving around 6 30 today if that works for you. I'd have to stop and buy a grease gun and grease though
    tonered[QUOTED] likes this.
  5. Dec 12, 2018 at 2:48 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    6.30p or so should work. PM incoming.
  6. Dec 12, 2018 at 3:21 PM
    Stanky taco
    Stanky taco Well-Known Member
    Auburn
    16 Tundra 1794 CM / 11 FJC / 19 GX460 / prev 13 TACO DCSB OR
    watch how you store your grease gun or else a puddle of red sticky substance may be on your garage floor...i found out the hard way.
  7. Dec 12, 2018 at 3:32 PM
    eon_blue
    Azusa, CA
    Greasing the u-joints until grease oozes out is fine, but don't overgrease your slip yoke...that is if you 2nd gens have one (I'm not sure). On the 1st gens, over-greasing the zerk on the slip yoke can cause it to fail. Plus it'll sling a ton of grease everywhere underneath the rear of the truck when you're driving.
  8. Dec 12, 2018 at 4:09 PM
    20somethingwidataco
    Will
    Washington State
    I have no clue lol
  9. Dec 13, 2018 at 7:19 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Haha! That is true. I have mine hanging on the garage wall and was not careful about the hoses. In the summer heat, both guns oozed a bit on to my derped grille and ruined a couple spots.
    I looked and felt around the slip yoke and couldn't find a zerk on @Kidwidataco 's. Or do you pump it in the end with a needle adapter?
  10. Dec 13, 2018 at 8:27 AM
    eon_blue
    Azusa, CA
    Our's has a zerk right at the last joint before the driveshaft goes into the rear diff (2 actually, one for the u-joint and the other for the slip yoke) It isn't right on the slip yoke but it provides the grease for it
  11. Dec 13, 2018 at 8:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! I didn't look near the rear diff for a fitting other than the u joint. We got all five on the shafts and checked the u bolts. I looked and felt all around the carrier bearing and found nothing. @Kidwidataco now has a grease gun, so he will be able to hit that if there is one.
    Some 3rd Gen folks have installed a zerk on the bottom of the carrier bearing. I have a couple laying around and have been thinking about doing that.
    I do need to look under there again since I think the slip yoke for the 2nd and 3rd Gens is at the carrier bearing? You question has me doubting things. :D
    eon_blue[QUOTED] likes this.
  12. Dec 13, 2018 at 8:36 AM
    eon_blue
    Azusa, CA
    yeah don't take my word for it, I'm sure your guys' driveshafts are entirely different than ours...but I imagine the same rule applies for the slip yoke if it is indeed greaseable...don't want to over grease it
  13. Dec 13, 2018 at 8:36 AM
    20somethingwidataco
    Will
    Washington State
    Lol ya I still need to buy the correct sized one for the bigger grease tube
  14. Dec 13, 2018 at 8:38 AM
    eon_blue
    Azusa, CA
    Harbor Freight sells them for cheap, although they aren't that expensive at regular auto parts & hardware stores. Make sure you get the kind that has the flexible/bendable hose... the solid hose kind makes it really hard if not impossible to get them onto the zerk fittings
  15. Dec 13, 2018 at 8:39 AM
    #35
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sounds good! Thanks. :cheers:
    Hahaha! Pfft! That's a minor problem. :spending:
  16. Dec 13, 2018 at 8:41 AM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. We talked about that. I showed him mine with the flexible hose. :rofl:
    HF also sells flexible hoses and other parts if needed. I do like the one that I linked above from HF because it has a pistol grip, which makes it a bit easier for doing it with just two hands.
  17. Dec 13, 2018 at 8:41 AM
    #37
    Wulf
    Wulf no brain just damage
    rock raisin
    What fails?
  18. Dec 13, 2018 at 8:43 AM
    #38
    eon_blue
    Azusa, CA
    I remember reading about it in the 1st gen 'what did you do' thread, too much grease and it can't slip the way it is supposed to or something like that, restricts it's movement. I imagine you have to pump a lot in there though. Before I knew any better I used to put a bunch in there and it would make a freaking mess under the truck for the next week of driving, grease getting flung out all over the place
    tonered likes this.
