Shorten my truck!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RickDC, Jun 11, 2012.
  1. Jun 12, 2012 at 9:47 AM
    #41
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    I wish I was about 3 inches to long.....:anonymous:
  2. Jun 12, 2012 at 9:56 AM
    #42
    TRDfarmerTN
    TRDfarmerTN Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    just get a rollpan if u dont tow much..even at that u can get a hideaway hitch thats flush underneath
  3. Jun 12, 2012 at 9:57 AM
    #43
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Buying any piece of real estate which has HOA is an epic fail.
    This comes from someone who has been in real estate for 9years.
  4. Jun 12, 2012 at 10:04 AM
    #44
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Where is the electrical distribution box above the tailgate height? Do the wires go just up or both directions? Which way do the stairs run? Do they go up toward that wall or at an angle along that wall? If they go toward the wall & no wires below the box it's possible to cut the drywall & XS and re frame the hole like a window opening. Hope it works out for you. If not you could try hitting a brick wall in reverse doing 40 MPH or better then it would fit.
  5. Jun 12, 2012 at 10:26 AM
    #45
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    What about getting a garage door that is flush with the Outside wall not the inside ghat would give you 6 inches or so. Call a garage door man to look at it.
  6. Jun 12, 2012 at 10:31 AM
    #46
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    ^This was going to be my suggestion.
    Easier said than done of course.
    You'd probably have to fab a new hitch receiver, etc.
  7. Jun 12, 2012 at 10:42 AM
    #47
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Step 1: try and squeeze it in there.
    Step 2: Make room!!!
  8. Jun 12, 2012 at 11:15 AM
    #48
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    This^^ You would need carriage style garage door hinged on the outside. You may be able to buy some that look similar to the ones you got there cheaper depending on the style. If not, custom garage doors will cost you. Worth a look.
  9. Jun 12, 2012 at 1:18 PM
    #49
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just thinking here. It would be cheaper to modify the front wall instead of the door. Outside walls are bearing walls so you have to build a header like what they do over a window or door. At worst you'll gain 4 inches removing sheet rock and 3 1/2 " studs in a false window you'll build. At best, which many modern buildings now use you'll gain 6 inches because the exterior walls use 5 1/2 studs. Take 2 2x8 lengths of douglas fir wood with a sandwich of 1/2 inch plywood and build a header to support the weight. Make sure you rest that on trimmer studs. This way you can span about 6 feet of area that your truck will fit into. Google door framing and you'll see what I mean. All you need is to leave the outside sheathing in place and no one will ever know. Everything under the header you build can be removed. If you don't know much framing then get help. I'd do it. It's like adding a door to an existing wall without the outside wall removed. You could do this by yourself for less than $100.
  10. Jun 12, 2012 at 2:36 PM
    #50
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    This reminds me of when I was buying my house. I have a 1971 Eldorado that's almost 19 feet long. While I was looking at houses I carried a tape measure and measured the length of the garage. I actually passed on a few houses simply because the car wouldn't fit in the garage. As it is now I only have like 6" of clearance front to back in the garage.
  11. Jun 12, 2012 at 3:50 PM
    #51
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Bob the bed as others said
  12. Jun 12, 2012 at 3:53 PM
    #52
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pull off a sheet of drywall , cut out the studs and put a header over the opening needed to clear the rear of the truck
  13. Jun 12, 2012 at 3:55 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Like put a short bed onto his longbed frame ?
    That would be awesome if you wanted an extra foot of clearance between the cab and the bed .
  14. Jun 12, 2012 at 4:07 PM
    #54
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i bet the HOA needs to approve house paint colors. changing to a new style door would be a hard sell.
  15. Jun 12, 2012 at 4:09 PM
    #55
    aficianado
    back to bone stock.
    how long is a DCLB? i can do the trig to see how high his ramps need to be..funny. i bet he would need to go up 2-3 feet in the front.
    like drive up on ramps?
  16. Jun 12, 2012 at 4:10 PM
    #56
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
  17. Jun 12, 2012 at 4:20 PM
    #57
    mike1025
    mike1025 Well-Known Member
    mike
    Oceanside, Ca
    08 DCLB 4x4 SR5
    Firestone ride-rites airbag, bed speakers, bull bar and 14" light bar
    My 08 is 224 inches bumper to bumper(but could be +/-2 inches)
    For giggles i did the trig for it...doesn't look like a very viable option:D
  18. Jun 12, 2012 at 4:28 PM
    #58
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thats a great idea. OP, can we see pics of how close of a squeeze you are talking about?
  19. Jun 12, 2012 at 4:41 PM
    #59
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
  20. Jun 12, 2012 at 4:46 PM
    #60
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    how high did you have to figure the ramp to be?
