should i also replace my coils?
Discussion in 'Suspension' started by mcleod90, Aug 25, 2011.
  1. Aug 25, 2011 at 9:46 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    i have a high mileage tacoma (150,xxx) and i plan on getting bilstiens for it. but my question is should i also replace the coils up front? i plain on setting them at 2.5"
    and for the rear i plan to get bilstiens back there to but should i just get a new leaf pack instead of the AAL?
  2. Aug 25, 2011 at 9:49 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    AAL will be fine. You will have to use the stock coils if you're going to compress them to 2.5" on the 5100s.
  3. Aug 25, 2011 at 9:52 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    ok thanks. would it be a good idea to put billys in the back to? or do you think i can get away with just the fronts for now?
  4. Aug 25, 2011 at 9:56 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yes 100% replace your coils, don't have to end up doing it twice!
    go with ome or eibach, I have ome and they are nice, the eibachs will give some more lift and the ome will make yo sit level If you keep the stock leafs,
    and you would be just fine without replacing your rear shocks right away, but you'll notice a nice difference when you do, the biggest difference
    will be up front though, also if you get new coils that are longer, set your 5100;s at the 0 setting not the 2.5
    this is ideal for the smoothest ride
    good luck! :thumbsup:
    I also recommend removing your sway bar, just slow down on those corners!
  5. Aug 26, 2011 at 6:57 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    One guy saying I should and one guy saying I shouldn't. Anybody else have any input. I guess I could always add the coils later if I needed.
  6. Aug 26, 2011 at 9:18 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Need them? No, will they improve ride quality/handling? Yes... you decide.
  7. Aug 26, 2011 at 12:35 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    He is saying if you want to set the bilsteins that high, stay with the stock coils,
    because you DO NOT want to set them that high if you get ome/eibach coils which will provide the lift instead of the shock compressing your stock coils,
    You'll regret it if you don't replace them now either with oem replacements or lift coils,
    because you will either have to do the work twice, or pay for it to be done twice.
  8. Aug 27, 2011 at 12:56 AM
    mcleod90
    sean
    modesto ca
    05 double cab
  9. Aug 27, 2011 at 10:09 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  10. Aug 27, 2011 at 10:14 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  11. Aug 27, 2011 at 10:16 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
  12. Aug 27, 2011 at 10:19 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Whoops lol
    that was my link from the wheelers bookmark I have,
    naturally 1st gen :eek:
  13. Aug 27, 2011 at 10:21 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Well, of course. The best option is to sell the 2nd gen and get a 1st. Der.
  14. Aug 27, 2011 at 10:27 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
  15. Aug 28, 2011 at 9:18 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Is it hit or miss with the vibrations when you set them at 2.5"? Having new coils and setting the bilsteins at 0" will that help eliminate possible vibrations?
  16. Aug 29, 2011 at 9:42 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    And you replace the ucas when you go over 3"? So if I just set them at 1.75" I should be good?
  17. Aug 29, 2011 at 1:08 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    If you have the money, Replace them now while your doing the work, in case there are alignment issues, if not you will probably be fine, I haven't replaced mine yet but then again I have a 1st gen
  18. Aug 29, 2011 at 7:35 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    ok thanks for everybodys input. i guess ill save a few more dollars and go with 884 OME coils with the bilsteins set to 0" and then go with a 1.5" AAL or should i go with 2"?
