Should I be worry about my Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by hal1999, Jul 2, 2015.
  1. Jul 2, 2015 at 11:33 AM
    hal1999
    hal1999 [OP] Member
    CT
    Toyota Tacoma Pick-up
    tonneau cover
    IMG_4422.jpg Hi
    I've got a '99 Tacoma reg cab rear wheel drive. I am planning to go away for a month. Can anyone tell me if it would be ok to leave it in the garage while I'm away.
    This is my baby and it just turned 200k
  2. Jul 2, 2015 at 11:35 AM
    Aw9d
    Aw9d That one guy
    I've not drove my truck for 2 months just because I work from home and didn't have a reason to drive it. You'll be fine. I'd disconnect the battery but it might not be needed.
  3. Jul 2, 2015 at 11:36 AM
    hal1999
    hal1999 [OP] Member
    CT
    tonneau cover
    Thank you - that's a relief
  4. Jul 2, 2015 at 2:36 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    fuel stabilizer isnt a bad idea either. especially if your fuel has ethanol or other blends in it.
  5. Jul 2, 2015 at 5:16 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    and park it with a full tank, empty gas tanks make condensation from the air in the tank and it adds water to the gas
  6. Jul 2, 2015 at 5:17 PM
    stombs
    stombs Well-Known Member
    Scott
    New Jersey
    2013 Tacoma V6 4x4 Access Cab TRD sport
    weather techs, westin grille guard, cb radio
    Disconnect the battery and fuel stabilizer and keaker makes a good point but overall you should be fine
