Should I Buy This Kit?????
Discussion in 'Long Travel Suspension' started by Rextinkleton93, Nov 24, 2013.
  1. Nov 24, 2013 at 9:41 AM
    Rextinkleton93
    Rextinkleton93 [OP] Well-Known Member
    Kyle
    Phoenix, AZ
    07 Double Cab PreRunner
    I don't really even know anymore
    hey guys, found a great deal that i just don't think i can pass up. Total chaos 3.5 kit (2005+) and i want it! My concerns are as follows...
    1. Uniballs have a small amount of rust, will i have to replace these?
    2. The piece that the lower uniball sits in and connect to the spindle has surface rust.
    Other than these issues, everything is a little dirty but straight, and all welds look good! Shocks are also included, and I'm thinking i should rebuild them. Price for everything... $2500!!!!
    What do you guys think? Thanks in advance!
    (the arms are dirty, that is not rust)
  2. Nov 24, 2013 at 9:44 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    doo it, for that price it's really good:cool:. uniballs are cheap and easy to replace when arms are off the truck. and uniball adapters will clean easy then, you can paint them to protect them too. just a lil maintenance and it'll be like a brand new kit again. rebuild, uniballs, a lil paint
  3. Nov 24, 2013 at 9:46 AM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    thats what I'm thinking :D any suggestion on uniballs????
  4. Nov 24, 2013 at 9:49 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Fk uniballs....get it
  5. Nov 24, 2013 at 10:23 AM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    this kit will work with my maxtrac spindles until i can afford a fabricated spindle, correct?
  6. Nov 24, 2013 at 11:59 AM
    anthony250f
    Anthony
    San Diego, CA
    Not unless you make custom spacers to fit the adapter into the double sheer....sell the spindles to me :spy:
  7. Nov 24, 2013 at 12:38 PM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    haha i saw you were looking for some, but like you i want to keep the preload off the shocks, and i don't think i would clear my 315's. Can you elaborate on the spacers?
  8. Nov 24, 2013 at 1:05 PM
    flesh2
    flesh2 Well-Known Member
    08 DB Cab long bed
    TC Lt, Dmz kit, Hnm bedcage
    You'll also have to get TCs new heimed uppers with the bend in the arm in order to run spindles . Other wise it throws off you're alignment somehow . That's what I was told by Total Chaos
  9. Nov 24, 2013 at 1:30 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    what size are those lower uniball ball and cup size? i need to make that mount for my lowers
  10. Nov 24, 2013 at 2:05 PM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    hmmmm, I've never heard that before.
  11. Nov 24, 2013 at 2:30 PM
    anthony250f
    Anthony
    San Diego, CA
    that shouldnt happen considering the geometry is the same as a stock spindle just raised 4 inches. plus you still have the lower cams....plenty of people run tc with camburg spindles.
    the lower uniball adapter is thinner than the stock bj adapter, so it needs spacers under it to fit snug in the spindle.
  12. Nov 24, 2013 at 3:00 PM
    flesh2
    08 DB Cab long bed
    Yea I didn't understand why it wouldn't work either :/.If I remember correctly TC said I would need to keep my preload at 3" to get a proper alignment , so combine that with the spindle and you'd get 6" lift . Supposedly the new bend in the arm is what helps with that .
  13. Nov 24, 2013 at 3:09 PM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    i guess i can see that, maxtrac cause camber to be out a little i feel like... haha
    so if i run the stock spindle with the tc kit, i wonder how high i will have to preload to clear my 315's? I'm going to get glass obviously but it will probably be a week or two after i get the kit on.
  14. Nov 24, 2013 at 3:10 PM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    flesh what size tires you running?
  15. Nov 24, 2013 at 3:25 PM
    flesh2
    08 DB Cab long bed
    I'm running 285s with about 3" of preload , everything clears fine with them . You'll prob have to cut some of the cab mount to clear the 315s
  16. Nov 26, 2013 at 8:27 AM
    Rextinkleton93
    Kyle
    Phoenix, AZ
    so I will be taking my maxtrac spindles off and running factory spindles for now, so to clear my 315's I'm thinking...
    -fiberwerks fenders
    -cab mount chop
    -preload the coilovers lol
    any one have anything to say about how this will work? little nervous hah
    also if any one like working on trucks i wouldn't mind buying pizza and drinks for anyone who wants to help me out a little. never put on long travel (put on two db lifts on my friends' trucks and took mine off) haha
