should i get say a 4 or 5 in
Discussion in '1st Gen. Tacomas (1995-2004)' started by djford193, Feb 16, 2010.
  1. Feb 16, 2010 at 7:19 PM
    djford193
    djford193 [OP] Member
    David
    Panama city
    2000 tacoma
    suspension lift instead? how much would that run and would it cause less problems then a body lift on my 2000?
  2. Feb 16, 2010 at 7:20 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    4x4?
  3. Feb 16, 2010 at 7:21 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    "should I get say a 4 or 5 in"
    That's what she said!!!
    :D :D
  4. Feb 16, 2010 at 7:26 PM
    djford193
    David
    Panama city
    2000 tacoma
    yeah 4x4..and lmao to the thats what she said joke
  5. Feb 16, 2010 at 8:02 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    other than pro junk stuff like this: http://www.offroadunlimited.com/orustore/pc/viewPrd.asp?idproduct=2034
    i have never really seen anything more than a 3 inch lift thats worth a crap. and of course the 6 inch drop brackets but that expensive, and not to much flex from what i have heard. if it was me personally i would get a good CO and leaf pack 3 inch lift and then get a body lift to match what ever tires i wanted.
  6. Feb 16, 2010 at 8:06 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    No bueno on body lifts. Hard on steering components.
  7. Feb 16, 2010 at 8:12 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    uhh every body hating. some of the sickest rigs i have ever seen have body lifts on them. if you do it right there not that bad. but yes if you can avoid them then its a good idea.
  8. Feb 16, 2010 at 8:23 PM
    djford193
    David
    Panama city
    2000 tacoma
    yeah then im gonna probly put a 3 or 4 sus lift then possibly add a small body later on..eventually when i make some money
  9. Feb 17, 2010 at 12:01 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    actually if everyone wants to bash a bodylift..... suspension lifts on ifs trucks are a lot worse than bodylifts. they make more extreme angles on your cv axles, driveshaft, and ball joints. Love my bodylift along with my suspension lift.just my two cents.
  10. Feb 17, 2010 at 6:58 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    the $ difference between 3 and 4 is HUGE, for 4 inches you'll need a drop down bracket, which is over a grand, plus coilovers and lifting the rear, you can do a moderate lift that will be just as, if not more competent offroad for under $600, add some sliders and you'll be better off.
  11. Feb 18, 2010 at 5:52 AM
    djford193
    David
    Panama city
    2000 tacoma
    idk wat ima do lmao. i just wants 3 in in the front so i fit some 32's under
