Should I get wheel spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SR54x4, Nov 7, 2010.
Should I add wheel spacers?
Poll closed Dec 7, 2010.
  1. YES
    66 vote(s)
    67.3%
  2. NO
    32 vote(s)
    32.7%
  1. Nov 7, 2010 at 2:10 PM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    So back in september I made a thread asking how safe wheel spacers are. Long story story short few people replied saying not really, the thread died, and I decided against them. Then a couple of weeks ago someone brought the thread back and a bunch of people said they are perfectly safe to use as long as you get the correct ones and instal them properly. Here is a link to the thread... http://www.tacomaworld.com/forum/2nd-gen-tacomas/114559-wheel-spacers-safe.html
    To sum things up the truck specs are as follows....
    2010 Access cab 4x4 4cyl manual
    it has 1.75" billies on the front and rear spring tsb
    265/75/16 duratracs on stock steelies.
    I want to add the wheel spacers simply for looks, I have NO rubbing issues at all.
    Please vote yes or no if you feel they are safe to use on my DD and if you don't mind just leave a little feedback as to why you say yes or no.
    I don't want to add something thats dangerous to my DD and ending up in a wreck or risking anyones safety just because I wanted to make my truck look better. Safety is more important than looks any day.
  2. Nov 7, 2010 at 2:13 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Many members on here have spidertrax wheel spacers. I believe they are the most reliable ones.
    If they are properly installed i think they would be safe. Im sure other people will chime in here. Good luck!
  3. Nov 7, 2010 at 2:15 PM
    SR54x4
    Mark
    Hudson Valley
    Thanks, I should add, if I do this I will be going with the spidertrax.
  4. Nov 7, 2010 at 2:41 PM
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    I'd say yes... BUT, I have no experience with them other than the fact that I want some because they look good, If I got a set they would be purely aesthetic as well...
  5. Nov 7, 2010 at 2:46 PM
    nhab
    nhab Active Member
    Wailua
    06 Taco
    I have run them on jeeps, fords and now my Taco. I trust them, have wheeled them hard, and put many hwy miles on them, on all vehicles, with no problems ever. just my 2c.
  6. Nov 7, 2010 at 2:56 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    So I currently run spidertrax on my tacoma I have 265/70/16 and for whatever reason after my 2.75 lift with my toytec coilovers my right side rubbed the lower control arm the hub and alignment were perfect but they could not figure out why it rubbed. So I decided to buy spidertrax just for the front to widen the stance and get rid of that rubbing. It work and I love my spidertrax I have had no problem and with the wider stance I have better control of the truck. I say go for it man when installing them just use a torque wrench not a impact gun. 80 lbs of torque and your all set
  7. Nov 7, 2010 at 2:58 PM
    socal4x
    socal4x Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    I was thinking about getting spidertrax too, because I want to keep the stock rims for now.
    Problem I've had in the past (with my Jeep) is that no local tire shops will touch the truck with them. I had to remove them first, pita:mad:
  8. Nov 7, 2010 at 3:03 PM
    DiamondDG
    DiamondDG Well-Known Member
    Central Cal
    2010 Prerunner DC TRD Sport
    3" Ready lift SST lift, Magna Flow cat back exhaust, Volant cold air intake, Grillcraft MX grill, N-Fab Prerunner light bar w/ 4 Hella 7 series lights
    Pay close attention to wether they are hub-centric or wheel-centric. Makes a difference. My buddy used hub-centric on hs Tundra and the steering shook. It was an expensive experiment. Once they were mounted they would not take them back.
  9. Nov 7, 2010 at 3:13 PM
    crawlerdog
    crawlerdog Member
    Scott
    New Mexico
    2010 Toyota Tacoma access cab 4x4 TRD OR
    Billies all around with 2.5" in front, TSB with Toytec 1.5" AAL, 265/75/16 Yokohama Geolander AT-S Redline Elite struts, Ultragauge, Yaseu FT-7900 radio, Leer XL topper, Westin nerf bars.
    Do you have to get an alignment if you install wheel spacers??
  10. Nov 7, 2010 at 3:13 PM
    SR54x4
    Mark
    Hudson Valley
    yup, looks like I need the hubcentric ones.
  11. Nov 7, 2010 at 3:27 PM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    yes if your a second gen you need hub centric and no you do not need to get a alingment after install
  12. Nov 7, 2010 at 3:50 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    What about the all pro hub centric spacers?
    They are identical and would come out 60 bucks cheaper for all four
  13. Nov 7, 2010 at 4:09 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    :popcorn:
  14. Nov 7, 2010 at 4:25 PM
    tacomaintraining
    tacomaintraining Well-Known Member
    I too want a set of spacers for my FJ trail teams black wheels. I just want to make sure they are safe. Can you install these yourself???
  15. Nov 7, 2010 at 5:20 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Yes they are safe, just follow instructions precisely. No impact gun, use a torque wrench.
    Yes you can install them yourself
  16. Nov 7, 2010 at 5:21 PM
    tacomaintraining
    cool thanks
  17. Nov 7, 2010 at 5:23 PM
    JLamb11
    JLamb11 Well-Known Member
    Jared
    Orange County, CA
    08 PreRunner TRD Sport
    Regear, 6" Pro Comp Lift, Wicked Flow Exhaust, K&N Intake, T-Rex Billet Grill, Cobra CB, Wilson Flex 3', Radio Shack PA, Eyelids, Xenon HIDs, Tint, Kenwood GPS/DVD/Bluetooth...
    I have heard you may get a lotta shaking up front
  18. Nov 7, 2010 at 5:31 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i have them on my ATV :popcorn:
  19. Nov 7, 2010 at 5:41 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    I say do it.
    I had spacers on my VW GTI before I got my Taco. I ran them for almost 2 years and never had any issues (different application, but same concept). If you install them correctly and torque them to the proper ft/lb then all should be good. I have heard good things about the spidertrax, and eventually plan on getting them myself.
  20. Nov 7, 2010 at 5:57 PM
    SR54x4
    Mark
    Hudson Valley
    thanks for the responses, keep them coming!
