Should I go with the 33"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bacobits24, May 26, 2008.
  1. May 26, 2008 at 11:03 PM
    bacobits24
    bacobits24 [OP] Member
    5inch Trailmaster lift
    Well I recently just invested in a 2003 tacoma. Anyway I am installing a 3 inch lift kit but they say it works only for 32" tires. Should i Go for the 33's? If so what are the disadvantages? If any at all.
    Thanks!
  2. May 27, 2008 at 8:18 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Well... I did, and I think they look better then the 32's I had before. I actually went with 285/75/r16, which is actually like just under 33's but close enough to be called 33's, I think they measure 32.85 or so. But I had slight rubbing with the stock wheels on the frame at full turn, and on the UCA. So If you do go 33's, I highly recomend new wheels with a less back spacing, I went with a 4-1/4" BS, which was perfect. I got no more rubbing. Oh... and you might have a slight change in MPG. But thats about it.
  3. May 27, 2008 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just an FYI, the way tires are mesured, they are rounded up. So, a tire that mesures 32.3" is considered a "33" and so on. :)
  4. May 27, 2008 at 8:26 PM
    ETaco23
    Evan
    PNW
    Gotchwa!! thanks chris... now I know.
  5. May 27, 2008 at 8:32 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    all depends on the offset/backspace of the wheel you run
  6. May 27, 2008 at 9:45 PM
    bacobits24
    Ohhhh ok. I was just afraid of rubbing haha.
