Should I install a 1/4 inch spacer on driver side?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HardG, Jun 23, 2019.
  1. Jun 23, 2019 at 7:50 AM
    HardG
    HardG [OP] Member
    Corey
    Dallas
    2018 White Tacoma TRD Sport
    265/70r17 KO2 American Racing wheels Eibach stage 1 lift Single AAL SR bezel Front camera RCI skid plate Interior LED upgrade
    I’m getting the eibach 2inch lift kit installed on Wednesday, along with a single 1.5 AAL. Some posts I have read mention they get the “taco lean” after lifting the truck. Should I proactively have the 1/4 spacer added to the driver side? I want to get this right to first time.
  2. Jun 23, 2019 at 8:16 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Investing in a set of adjustable coilovers would be getting it right as they can be set to compensate for the lean. Adding a spacer to an existing non adjustable coilover will limit its performance...be better off leaving it as is because performance is better than looks in this situation.
