Should I install radio myself or take it in?
Discussion in 'Audio & Video' started by loaderman82, Nov 21, 2010.
  1. Nov 27, 2010 at 6:46 PM
    81shark
    81shark Well-Known Member
    150 to install a radio at best buy???
    what a rip
    do it yourself
    or bring it to me, and i'll do it for 50 bucks
  2. Nov 27, 2010 at 6:51 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea. As long as you have at least a very basic understanding of wiring you're good to go. Basically just matching up color coded/labeled wires and either soldering or using butt connectors or something similar. I soldered my connections, I like to think I'm decent at soldering. Although some good butt connectors might be better than a poor solder job. I've had professional installs in the past just because I had never worked with any kind of wiring but since then I've had some experience and I did the Taco install myself. Soldered my connections on the harness myself and pretty much cake from there just plug and play and doing any other extras for your HU.
  3. Nov 27, 2010 at 8:17 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    I like to use small insulated closed end splice caps in lieu of butt connectors. All too often I have been checking someone's wiring and was able to pull their butt connector apart by hand. I think they're just more difficult to work with for some reason.
  4. Nov 28, 2010 at 5:11 PM
    81shark
    i use the screw on connectors topped with electric tape. multiple installs with zero issues.
  5. Nov 28, 2010 at 5:26 PM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    I ended up putting my AVIC-Z120BT in this weekend and it was cake... you shouldn't have a problem with putting that unit in. :cool:
  6. Nov 28, 2010 at 5:43 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would check the directions you get when the unit arrives, if you can follow everything, go for it. No need to shell out the extra money. Best Buy uses those quick crimp connections and don't take the time to solder and heat shrink the connections like it should be done (at least in my opinion that's the correct way to do wiring). Don't just solder connections and wrap them in electrical tape and call it a day.
  7. Nov 28, 2010 at 6:31 PM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    Do it yourself. Get wiring kit for tacoma off eBay or other source and scosche kit. Easy to wire. I used the twist caps to wire only because if I made a mistake I could correct it easy. Be aware of the Orange wire though. Sometimes named dimmer wire or other. Gave me a problem and others I talked to. Don't connect if you don't have to. I routed Gps antenna, ipod hook up and it all was a breeze. Now I'm thinking subwoofer! The tacoma is one easy truck to work on.
  8. Dec 12, 2010 at 10:22 AM
    cavilry
    cavilry Well-Known Member
    San Jose, CA
    06 Tacoma TRD 4x4 LT
    Total Chaos Long Travel Kit, King Shocks, Deaver Leafs
    I just got my AVICU310BT in and am in the middle of my installation. I am having a hard time matching up the colors. It seems like some of what is on one is not on the other, and vice versa. I have the wiring that came with the unit and the wiring that came with my ********* kit but....
    Also, the Pioneer unit has a different type of connector for the speakers than it looks like the stock one had, so I can not figure out which one thes are (I know...I am kinda dumb). Does anyone have a wiring diagram or know where to find one?
  9. Jun 22, 2011 at 3:14 PM
    rolltyd
    rolltyd Well-Known Member
    Jay
    Overland Park, Kansas
    2013 Off Road 4x4 Hankook Dynapro ATM
    Anybody know of a good place to get hu installed and speakers in JOCO Kansas? I am about to puchase but Santa Fe and Best buy want way too much to do it.
  10. Jun 22, 2011 at 3:39 PM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    Soundperformanceonline.com is a seemingly good place for that; they've got 8 good reviews. Not sure if that's close enough for you.
  11. Jun 23, 2011 at 5:23 AM
    rolltyd
    Jay
    Columbia Mo is a hour and a half away from me . Thanks though. Anywhere else you know of ? More to the west
  12. Jun 23, 2011 at 5:41 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i'm actually about to take my truck back to best buy because every time i hit a bump the entire radio moves in the dash.
  13. Jun 23, 2011 at 5:43 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    btw way this will be the third time i have to go back the last time the radio fell back into the dash
  14. Jun 23, 2011 at 6:23 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what double din dash kit can secured using screws like the factory one to increase its strength? the last time the truck was at best buy they used epoxy to seal the kit and trim ring together i knew something was wrong right there.
    one more question can the factory backup camera be used with an after market headunit my truck did not come with the factory back up camera and the one i bought sucks it big time.
  15. Jun 23, 2011 at 7:35 AM
    #35
    pinktaco808
    pinktaco808 Hot Steppa
    do it yourself
  16. Jun 23, 2011 at 12:36 PM
    #36
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    Soldering the wiring harness is the only thing that is involved and even that's not bad if you just take your time. Do it yourself imo...you'll know its done right and you also said you wanted the parking brake bypass done, many shops will not do that mod, so if you need to open up your dash anyway you might as well do the rest of the install. Amazon sells the wiring harness and the dash kit and past that you really don't need anything else other than a relay from Radioshack etc for the bypass.
  17. Jun 25, 2011 at 7:12 AM
    #37
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    imo, with the way things are now a days, it's VERY easy to install your own. Although if your doing a steering wheel remote yeah I understand that may need to be done by a professional.
    The wiring harness is easy as all hell since they are all colored matched the same pretty much no matter what model/make the vehicle your installing the aftermarket h.u. in. plus with the adapter panel, it's even more of a snap!
  18. Jun 30, 2011 at 7:58 AM
    #38
    LTE
    LTE NRA Benefactor Member
    in my own little world
    07 SR5II; Longbed; FLyzeyes LED
    window tint, step bars, Flyzeye LED interior console light
    If it's a matter of connecting a few adapters, try yourself. If it starts involving soldering and all kinds of wire cutting, you might consider paying someone else to do it (especially if you don't have the tools).
    Here's a prime example, when I worked at the music store, I sold this kid (well a 19 year old) a pickup for his guitar. I asked him he wanted us to install it for him, he said no, he thinks he can handle it.
    He comes back on my day off telling everyone that I don't know what I am doing and that I'm a liar, a piece of trash etc...because the pickup sounds horrible. After weeks of this, I tell the owner of the store to swap the pickup out one more time but this time, we install it for him for free to ensure no more screwups and then we'll be done with it (I was the guitar & repair manager).
    The repairman cracks the guitar open and the kid has used nothing but electrical tape to install his pickups.
  19. Jun 30, 2011 at 8:18 AM
    #39
    Mskwared
    Mskwared Well-Known Member
    I got that same kit and mine doesnt quite fit right. I did lose the top middle plastic clip though. Im only using the single din though
