Should I take "EZ Lube" seriously?
Discussion in 'Performance and Tuning' started by Styx586, Aug 26, 2011.
  1. Aug 26, 2011 at 12:14 PM
    Styx586
    Styx586 [OP] Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    So I took my truck into "EZ Lube" today to get the oil changed and they said that my trans fluid is really dirty and needs to be flushed, my rear diff has metal shavings in it, and my radiator needs to be flushed too cuz there's "corrosion" on one of the tubes. Then they quoted me $500 to fix it all. Should I look into these problems or are they just trying to get my money?
    Edit: my truck only has 56k miles on it I don't think i should be running into these problems yet... or should i?
  2. Aug 26, 2011 at 12:16 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Meh, look into it, But don't let them do any of the work!
  3. Aug 26, 2011 at 12:17 PM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    id take it somewhere else. I like to take my truck to the dealer or a mom and pop shop cause a dealer knows what they are talking about and mom and pop shops normally wont screw you over. I would never take my truck to a giffy or ez lube
  4. Aug 26, 2011 at 12:19 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    I'm pretty sure a retarded monkey could change the oil in a car/truck... and obviously if i'm getting extensive work done to my tuck i'll have a more credible place do it but thats not my question... Should i be worried about my diff/ trans?
  5. Aug 26, 2011 at 12:21 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Worried, no. But it is time to change your diff fluid if it hasn't been done...
  6. Aug 26, 2011 at 12:21 PM
    ERIC
    Eric
    Orange County, CA
    I wouldnt be but I would check it for myself
  7. Aug 26, 2011 at 12:23 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    how do they know there are metal shavings in the rear diff??? youd need to drain it to really see
  8. Aug 26, 2011 at 12:24 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Trans fluid can have discoloration at your mileage if you've done alot of towing......but I wonder how they know you having shavings in your rear diff. without breaking it open.....sounds fishy.
  9. Aug 26, 2011 at 12:24 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    I wouldn't trust any drive-through oil change place for my life. You have to have ZERO experience with vehicles to get a job there. I'd take it to experts, or the closest thing to that. Unfortunately, that may be a dealership.
  10. Aug 26, 2011 at 12:26 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2?
  11. Aug 26, 2011 at 12:28 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yeah I asked if they drained the fluid and he said they removed the plug (I'm assuming the fill plug otherwise the fluid would drain right?) and there was metal shavings on it... ?
  12. Aug 26, 2011 at 12:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I was wondering the same thing... and I think you have your answer about the credibility of EZ Lube. I'd look into getting the rear diff fluid changed though. 50k miles is about where you should have it done. A transmission flush couldn't hurt, I plan to do mine at 60k miles. No comment on the radiator, I don't mess with those.
    Personally, I don't think they checked any of those fluids and it just popped up in their screen as 'recommended' for a vehicle with your mileage.
  13. Aug 26, 2011 at 12:31 PM
    Yoytoda
    Roland
    completely stock
    not likely... they are just trying to solicit work from you...
    youd have to remove the drain...
    at your mileage you should do a full soup to nuts service
    60k service includes diff oil change, trans fluid change, rad flush, and a few other small things, plugs etc
    Just go to a reputable shop, not a drive through place like others have said
  14. Aug 26, 2011 at 12:32 PM
    Pugga
    Massachusetts
    Are the first gen plugs magnetic? Get the rear diff fluid changed if it hasn't been done before but not by that place. I don't trust places like that at all.
  15. Aug 26, 2011 at 12:32 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Check it yourself and see if there's any shavings. Have you ever had your diff fluid changed before? I mean, Your truck is an 01', it wouldnt be a bad idea to get it changed.
  16. Aug 26, 2011 at 12:32 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    EZ lube? Is this a Trojan product or a shop?
  17. Aug 26, 2011 at 12:33 PM
    clothar
    clothar Well-Known Member
    Vancouver
    98 V6 4WD Xtra Cab Limited
    I would have a look at all the stuff they mentioned. I was told on a vehicle inspection that the brakes and power steering needed to be flushed. When i got home an looked at the fluids they were both clean and free of dirt/burnt fluid.
    It really pissed me off that they told me that when it was obvious that they didn't even look at the fluids.
    Also how would they know that you had metal shavings in your diff? They would have to look at the magnet on the drain plug and wouldn't they have to drain your diff to look at said plug?
    You probably do have metal shavings in your diff but nothing to get worried about some metal shavings are expected through wear and tear the only time to get worried it when there are big shards.
    So have a look and if they are legitimate problems (which I doubt based on your mileage) but yeah good luck i think your truck will give you thousands more miles without problems.
  18. Aug 26, 2011 at 12:36 PM
    yota new.o
    yota new.o Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    ha ha very good point sir i would look into it but do it under the supervision of someone knowlegable. if you plan on owning this truck for a long time you should get comfortable doing the maintenance on it.
  19. Aug 26, 2011 at 12:38 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I would be pissed they looked at stuff you didn't ask them to,
    Thats what you take it to a trusted mechanic for,
    what if they stripped your diff fill plug? or when they put it back on it was some kid with
    an impact that was all torque happy?
  20. Aug 26, 2011 at 3:34 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    So I went to a Toyota dealer and talked to one of the Techs about the rear diff thing... and he said the rear diff fluid is really thick and you can remove the plug without any of it draining out, then you can wipe ur finger on the inside and see if there are any shavings. He said the 60k service covers rear diff, trans, radiator, and spark plugs. My truck is at 57k miles so i'll be getting this done soon.
